Results 1 to 4 of 4
Thread: Sears Kenmore Electric Range 790.94854300 F1 Clock Error
    Jan 2006
    USA
    Smile Sears Kenmore Electric Range 790.94854300 F1 Clock Error
    I had this problem with Sears Kenmore Electric after Power Drop (f-1) Code
    Found Answer at:
    (http://www.frigidaire.com/support/FAQ-New_Electric_Coil_Range.asp)
    9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
    • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
      Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
    This should help Kenmore and Frigidaire Range Owners. Frank
    Good information to know, thanks Frank!
    tjgirl is offline Member
    Jul 2006
    nova scotia
    Default Kenmore Range Blank Display
    This is to Frank aka Lewandowskiifrank. You are an angel. I have been looking for a resolution to my problem and I read your post today and tried your trick and vola! It worked like a charm. Thank you soooooo much, I have a display again on my Kenmore model C970-440223.
    Cheers
    tashama is offline Premium Member
    Dec 2007
    Portland
    Default Model 790.75903993
    Has anyone had this problem with the above mentioned model? We inherited with our house 3 years ago and the F1 code error just happened. It's 4 days before Christmas! And Sears want $225 for something I won't get until December 31st. I'm going to try the fixes for other models, but was hoping someone could talk on this particular model. Thanks.
  1. Replies: 9
    Last Post: May 14th, 2011, 08:37 AM
  2. Kenmore Electric Range Clock - 1986 model
    By rbarkerlr in forum General Appliance Chat
    Last Post: May 8th, 2006, 05:45 PM
  3. Kenmore Model No. 665.9200 electric range
    By opusfly69 in forum Sears Kenmore
    Last Post: March 8th, 2006, 12:23 AM
  4. kenmore electric range 665-95014102
    By ken-no-more in forum Sears Kenmore
    Last Post: February 3rd, 2006, 12:23 AM
  5. Slow Preheat with Kenmore Electric Range
    By bigredrocket in forum Sears Kenmore
    Last Post: January 22nd, 2006, 03:18 PM
