February 6th, 2006, 04:51 PM
Kenmore Elite HE3t loooooooong spin cycle
Kenmore Elite HE3t, Model No. 110.42922200. When the washer reaches rinse/spin cycle, the timer displays 1 min. but continues running for about 45 minutes. It doesn't matter which wash cycle is chosen. I searched your website and found someone who had a similar problem, (July 05). The suggested solution, which happened to resolve this persons issue by the way, was to unplug the washer for about 30 minutes. I unplugged mine for about 2 hours but the problem persists. Any suggestions? Also, where can I purchase a service manual for this washer? Any assistance would be greatly appreciated.
thanks,
dan
February 6th, 2006, 08:08 PM
Yes, the Repair Manual would be your best way of fixing this issue.
Here is the one for your model you can buy:
Whirlpool Duet- Kenmore HE3 Washer Repair Manual
February 9th, 2006, 11:42 AM
we've had the same issue almost since day 1.
a Kenmore repairman came out and said we should use HE detergent and that was out issue ad everything looked fine.
We got HE only detergent. NO matter how little we use it gets stuck on that 1 minute deal.
It doesnt matter what cycle. If I catch it on 1 minute, I have to stop and cancel the cycle and then do a drain /spin only (11 minutes) and it can finish, but it can be stuck on the 1 minute deal for almost 2 hours prior to this!
So what exactly is the issue?
February 10th, 2006, 12:35 AM
I seem to remember something about this, but i can't remember what we did to fix it, its been a couple years ago.
Hopefully another tech. or member will see this post and help you out.
You can also e-mail the RepairGuru.
February 11th, 2006, 01:41 PM
no help? : (
Seems we keep getting the runaround on this problem and it takes forever for me do laundry!
February 11th, 2006, 06:03 PM
File a complaint against Sears, its their machine. Call 1-800-4-MYHOME and ask for customer relations, it that doesn't work go to small claims court and the judge will solve the problem.
By Brittgee in forum Sears Kenmore
Last Post: July 26th, 2010, 08:05 PM
By OLDINVIRGINIA in forum Sears Kenmore
Last Post: February 26th, 2007, 05:25 PM
By smiley26 in forum Sears Kenmore
Last Post: January 13th, 2006, 07:43 AM
By mime in forum Sears Kenmore
Last Post: January 8th, 2006, 05:57 PM
By JoeZ34 in forum Sears Kenmore
Last Post: December 27th, 2005, 05:44 PM
