Old February 6th, 2006, 05:27 PM
Cwanger is on a distinguished road
Default F3 code repair on Kenmore oven
Looks like I have a common problem with the Kenmore built in oven. I'm getting the f3 code frequently, but not constantly and once I have received the f2 code. I found out the f3 code was the temperature sensor. From the manual it looks like I have to remove the oven box to get at the sensor connection. However after unscrewing all the screws along the front of the oven, the box starts to come out but catches. I'm afraid to really force it. Any suggestions? the oven is a Kenmore 24" dual built in oven, Model # 911.4132991
Old February 6th, 2006, 07:18 PM
I have changed a few of these, I usually don't have to pull the oven out from the wall, I usually just unscrew the sensor assembly itself from inside of the oven, then gently pull the electrical wire connection through that hole were the oven sensor mounts.
Old February 6th, 2006, 07:30 PM
I was hoping it would be that simple. I'll try again tomorrow and let you know what happens.
Paul
Old February 6th, 2006, 07:40 PM
Ok Paul, sounds good, let us know how it goes!
Old February 7th, 2006, 06:47 PM
I'll try this again. I just wiped out my reply when I tried to attach a picture of the sensor. I'll finish this post and try to send the picture in the next one so at least you'll get my post. I unscrewed the sensor and tried to pull it out as far as I could. I did not get to any type of plug in connection. I got maybe 5"-6" of wire before I was pulling on it and getting now where. Any further ideas?
If I get luck the next post will have a picture.
Paul
Old February 7th, 2006, 07:01 PM
Hopefully, I did this right. There should be an oven picture on here somewhere.
PAul
Old February 7th, 2006, 10:15 PM
Good Photo!
Ok, some have connectors, some don't that you can get to from the front.
If i can't get to the connector, i turn the breaker off to the oven, then snip of the end of the wires(near the sensor probe)with wire cutters.
Here is the new sensor for your model you can order, it comes with 2 cermatic wire nuts to connect it:
Old February 8th, 2006, 01:19 PM
Thanks again Jake. I've got the part on order so I'll check back in a few days to let you know how it works out.
Paul
Old February 8th, 2006, 10:34 PM
Sounds good Paul.
Old February 13th, 2006, 07:08 PM
I got the sensor today and wired it up, but it tripped off on an F3 again. I thought maybe the computer might need reset so I shut the breaker off for a minute and turned it back on. I set the oven for 200 and it seemed to work fine. Then I set it for 300 and as soon as it got to 300 I got the F3 error again. I can't return the sensor now that I cut the leads off. Do you have any other ideas that might not be as expensive. If I have to spend much more I should probably just bite the bullet and call the repairman. BY the way these ovens are at least 10 years old and maybe closer to 12.
Thanks again for the help.
Kenmore oven C970-688082 cooktop refuse to start with error code "F5" then "Er" pprevill Sears Kenmore 1 March 18th, 2007 05:18 AM
Kenmore F7 code double oven on both. X2 kimmy Sears Kenmore 1 December 10th, 2006 09:30 AM
Kenmore Elite Dual Fuel Oven Repeat Problems Model C970-445441 mudcat Sears Kenmore 3 January 11th, 2006 01:20 PM
Kenmore Electric Dual Oven Error Code F0 keystone Sears Kenmore 3 December 19th, 2005 07:24 PM
