1Likes
Post By Jake
January 12th, 2012, 02:42 PM
Kenmore Series 70 Washer Won't Agitate, Spin or Drain
Prior to completely not working my washer would make a sqeaking/squealing noise once in a while in the spin cycle, once in a while there would be a slight burning smell also. I don't think it was spinning the clothes as dry as they should be either. Now it fills but will not agitate, spin or drain. The next day it started to agitate but then quit and nothing works again.
If you could please give me a list, in order of priority, of things to check I would really appreciate it. Thank you.
January 12th, 2012, 05:23 PM
Remove the agitator and check the drive block. It sounds like the spin tube has worn through the drive block and dropped down. Look at the two drive blocks in the picture. The one on the right is what it's suppose to look like.
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
January 12th, 2012, 07:59 PM
Yes, I agree with Rick.
Here's the tub drive block for your model:
Manufacturer part number 389140 is RepairClinic item number 2858
389140
This video shows how to check and replace the drive block:
By btragesser in forum Sears Kenmore
Last Post: October 28th, 2012, 04:07 PM
By anguyen in forum Sears Kenmore
Last Post: August 24th, 2006, 02:57 PM
By jamespoky in forum Sears Kenmore
Last Post: July 16th, 2006, 04:49 PM
By otherjohn in forum Sears Kenmore
Last Post: July 11th, 2006, 10:22 PM
By arnierobert in forum Sears Kenmore
Last Post: November 22nd, 2005, 02:13 PM
