February 7th, 2006, 05:24 PM
1999 Kenmore SS not dispensing water
My 1999 side by side has quit dispensing water. Ice make still works fine. I can hear a "motor" sound when I depress the water button. I suspect the solenoid is working. I know there is an electical switch at the door access panel and a water valve in the back. Any suggestions......any past experiences????? Does the door access panel just snap off?
Thanks in advance for any tips.........
Jeff
February 7th, 2006, 11:00 PM
If you hear a humming sound when you press your water dispenser lever, then that dispenser switch is fine.
Its either your water inlet valve solenoid is stuck closed, or your water tank in the refrigerator is frozen.
Here is a link that should help you:
http://www.applianceaid.com/frig-dispenser.html
By KMF in forum Sears Kenmore
Last Post: November 19th, 2006, 12:25 AM
By octalman in forum Sears Kenmore
Last Post: October 27th, 2006, 10:25 AM
By z_bull in forum Sears Kenmore
Last Post: June 27th, 2006, 12:35 AM
By TJM40 in forum Sears Kenmore
Last Post: May 2nd, 2006, 10:48 PM
