Results 1 to 2 of 2
Thread: Kenmore washer intermittent burning smell
    mvmartin is offline Member
    Feb 2006
    CA
    Question Kenmore washer intermittent burning smell
    We have a Kenmore model 417 washer/dryer combo. Probably around 5 years old.
    We were running the washer the other day, and started to smell something burning in the washer. We stopped the washer and pulled out the clothes. The washer seems to run fine, just the smell.
    I tried to troubleshoot it today. Took the front panel off the washer to check the belt. Ran the washer (no clothes) to see if I could recreate the problem or see an obvious problem. Couldn't see anything, and there wasn't a smell. I think I've seen this once before.
    1) Any thoughts on what the problem might be? Belt slipping? Something falling on a hot motor?
    2) Also, while I've got it open, are there any surfaces that I should lubricate? If so, what type of lubricant should I use (can I use WD-40)?
    3) Of course, my biggest concern is that the washer could catch on fire. Does this happen with enough frequency that I should be concerned about the burning smell?
    Mark
    No, its almost unheard of for a washer to catch on fire.
    Its possibly the belt, if you use your washer daily or more than 5 times a week, that belt is probably starting to wear out and smell burned and slipping to much. Make sure the transmission moves freely when you turn the transmission pulley the belt goes around.
    Here is a link that should help too:
    http://www.applianceaid.com/frigwestwasher.html#burnt-belt
  1. Ge washer not spinning burning smell
    By sun45 in forum GE/Hotpoint
    Last Post: October 29th, 2006, 08:37 PM
  2. Replies: 3
    Last Post: October 22nd, 2006, 10:56 PM
  3. Kenmore 110 Burning smell
    By v3rone in forum Sears Kenmore
    Last Post: August 1st, 2006, 10:47 AM
  4. Maytag MAV8000 Washer - Burning Smell
    By kapdan in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 17th, 2005, 09:30 AM
  5. Amana Washer - Burning smell during spin
    By loriscottz in forum Amana
    Last Post: August 8th, 2005, 09:52 AM
