Results 1 to 6 of 6
Thread: Black flecks from icemaker Kenmore Coldspot
    bearly1227 is offline Member
    Mar 2012
    Boca Raton
    Default Black flecks from icemaker Kenmore Coldspot
    Model Number: 106.9651880
    Age: More than 10 years
    Black flecks on some ice cubes.
    Some advice was given in 2006 for a different model, and I wonder if the same advice would work for my model? The advice given was to replace either the mold or the whole ice maker.
    Refrigerator and ice maker works just fine. It is 16 years old, but is the part still available?
    Is the three screws that easy to replace, or is it more involved than that? I am pretty good with technical mechanical stuff and being careful.
    Bob
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Three screws and one wire connector. You'll be money ahead if you replace the entire ice maker. Here's the one for your machine:
    Ice Maker Assembly 4317943 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Black flecks from icemaker Kenmore Coldspot-ice-maker-assembly-4317943-01343956.jpg
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Mar 2012
    Boca Raton
    Thank You very much. Replacement was a piec of cake - - er - - -ice cream cake as it was still cold.
    I think I have another problem now. Since replacing the ice maker (yesterday morning, and reinstalling this morning), it is not making ice as quickly as before with the old maker. I made sure the plastic tubing fitted into the ice maker hole.
    Early this morning I had about 7 partial cubes. Like a shell with no contents. The Ice maker for this model is normally slow, but generally makes more ice than that in 24 hours. Is this in anyway normal? Is there an initial "fill" time before ot starts making ice? I don't have the User or Repair guide, so am uncertain as to how much ice per day to expect.
    Freezer temperature has been around 10 degrees, so it seems cold enough to make ice.
    Robert
    Hi Robert,
    Good job installing the new ice maker.
    So your getting what sounds like "Hollow" ice cubes now.
    Hollow cubes are always a sign of low water pressure to your refrigerator.
    First Pull your refrigerator out away from the wall, turn off your water supply line that goes to it, then take off your water supply line from the water inlet valve, then get a bucket, cup, bowl, etc to catch the water, then put your water supply line in the bucket and turn it on, your water stream should be really good with good water pressure, if not then the problem is in your plumbing water supply line.
    Let us know how the water pressure is.
    A very LARGE problem in the last few years has been the self piercing shut off valve clogging up with calcium and junk! Replace the self piercing shut off valve with a drill type shut off valve. You drill a 1/4" hole into the pipe and install the shut off valve the same way you would with a self piercing valve.
    Mar 2012
    Boca Raton
    Checked the mainwater valve for the ice maker, and it is not fo the piercing type, but more like what you fidn for sink and sanitary shutoff valves.
    The connection at the refrigerator end, showed free flowing aftear a short airgap. I suspect it may have had an air bubble in the line. My ice maker is a bit slow making ice. Today as I checked the half moon cubes (is that an oxymoron?) they were hard as clear ice!! Hallalewyah!!
    Thanks you very, very much!!
    Robert
    Ok sounds good Robert.
  1. Whirlpool Duet black rubber flecks
    By Vern49 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 29th, 2011, 09:27 PM
  2. [FIXED] Icemaker, Kenmore coldspot
    By bruce1964m in forum Sears Kenmore
    Last Post: March 11th, 2011, 07:51 PM
  3. Kenmore coldspot icemaker fixed
    By yuke in forum Sears Kenmore
    Last Post: January 23rd, 2011, 10:33 AM
  4. Kenmore Coldspot icemaker problem
    By nedareparmn in forum Sears Kenmore
    Last Post: September 25th, 2007, 10:42 AM
  5. Kenmore Coldspot, icemaker quit
    By Gin123 in forum Sears Kenmore
    Last Post: July 6th, 2007, 11:44 AM
Tags for this Thread
