LinkBack (2) Thread Tools Search this Thread Display Modes
  #11
Old April 28th, 2007, 06:23 PM
gschultz is on a distinguished road
Angry Freezer drain refreezes constantly
I am on my fourth cleanout/defrosting of the drain in the back of my [last] Sears/Kenmore fridge/freezer. I make sure it is clean by putting hot salt water down the drain until it flows freely. I also make sure all the ice is gone from the bottom of the freezer compartment. A month goes by and it is frozen shut again.
Any suggestions on keeping it open? Thanks.
Old May 25th, 2007, 12:25 PM
Bradleyappliancetech#1 is on a distinguished road
Moisture in the refrigerator usually means there is an airleak somewhere. Check your door seals. If you had a backup in the drain, you would probably find frozen water in the botton of the freezer.
Old September 15th, 2007, 09:05 AM
iwanano2 is on a distinguished road
Wink To keep water in freezer drain from freezing again
I have the same problem in my Kenmore model 2990. The solution to keeping mine from freezing again was to wrap a wire (something like a thick solder wire) around the heating element line just above the drain and then insert the wire into the mouth of the drain. This should stop it from freezing again.
What makes me mad is that Sears has known about this problem for years and has done nothing about it except charge customers for a field service repair.
Michael
Old October 17th, 2007, 07:31 AM
ghep17 is on a distinguished road
Default reappearing water inside Fridge...
We have a Whirlpool model#ET1PHKXPQ01 (I think that's the number) we bought in 2005 and have had the freezing up problem in the drain flow. The first time we paid somone to clear it out and he said it was probably food and we were very strict about bagging up all foods in the freezer but the problem came back. We used the hot water method to successfully clear the drain tube but now about 3 weeks later the water inside the fridge is back and there is ice again in the freezer blocking the drain. My wife is very frustrated. This is the first brand new fridge I have bought and it seems like from what I have read on this and other forums this problem cannot be solved. Is there any way to stop this from coming back? I read this post on the wire but could not understand the process and reason.... Help!!!!
Old October 18th, 2007, 02:02 PM
You might want to run something down the drain hole to make sure you don't have any obstructions.
Old October 18th, 2007, 02:08 PM
You can also use a piece of weedeater line.
Old October 30th, 2007, 10:26 AM
jrela2000 is on a distinguished road
would this work on a Kenmore 253.63712300?
Old October 30th, 2007, 10:35 AM
Yes, it should work on most models.
Old September 4th, 2009, 05:41 PM
kdrew is on a distinguished road
Default Follow up September 2009- Still OK
Originally Posted by kdrew View Post
No need for the compressor just patience. I actualy used a small piece of tubing to suck out the water in the drain hole and then added more hot water. This was repeated about 5 times to finally remove the ice blockage and allow free flow of water to the drain pan underneath the refrigerator.
Thanks again!
Just a follow up. I have had no issues since the fix. All seems to be working well. Perhaps I need to worry about it every 7 years or so since the fridge was 7 when we had the issue. We will see. Thanks for the great site to help owners who have some know how to stay informed and save a little cash!
Old September 4th, 2009, 08:05 PM
Excellent Kdrew, glad to hear its still fixed.
Who's knows you may get lucky and last longer than 7 more years.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/3109-fixed-water-build-up-inside-refrigerator-model-106-70277990-a.html
Posted By For Type Date
Water leaking inside my Kenmore refrigerator. - ApplianceBlog.com - Appliance Repair Forums This thread Refback September 12th, 2009 06:13 AM
Kenmore Coldspot Leaking Water All Over!!! - ApplianceBlog.com - Appliance Repair Forums This thread Refback September 2nd, 2009 02:18 PM
Water inside old GE fridge TBF16DYC Psurfer GE/Hotpoint 5 June 21st, 2007 08:44 AM
Leaking Water inside fridge (Defrost Drain clogged?) phazerwolf Whirlpool 1 January 24th, 2007 11:11 PM
Water on shelves inside refrigerator backazimuth2 Sears Kenmore 3 December 1st, 2005 06:26 PM
Water inside refrigerator Sneeze Whirlpool 1 September 22nd, 2005 03:49 AM
