Originally Posted by
On your model, its located behind the inside of the freezer behind that back access panel, just remove that back panel, and your freezer floor panel(Has 2 screws in front), that simply pulls out, then you will see it under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Thanks Jake!
Looks as if the entire bottom of the freezer was frozen solid. I unplugged the refrigerator and then allowed the thaw to start. To minimize the water going into the refrigerator, I plugged the holes with a paper towel. I had a microwavable heat pack that allowed me to avoid the massive amounts of water that looked as if would be needed. The ice sheets lifted up nicely after 10 minutes of so.
I carefully used a hairdryer on warm setting to clear near the drain hole. The drain hole was plugged well within it so I then resorted to hot water. Looks as it will be done in a little while (thus I type this now). If all goes well, I will not post again.
Question: if the drain hole is still clogged, is it wise to try to blow it out with a simple compressed air (set very low, obviously)?
