Results 1 to 3 of 3
Thread: Kenmore Washer spins slow...Clothes wet!
    jaimelynn_76 is offline Member
    Feb 2006
    Eagle, ID
    Cool Kenmore Washer spins slow...Clothes wet!
    I have a direct drive Kenmore, top loading washer, Model: 20936990, that is a few years old.
    It works fine in all cycles, except for spin. It pumps out the water and drains, but doesn't seem to get up to full speed during the spin cycle, leaving the clothes, even small loads or single items, soaking wet afterwards.
    Even re-running the spin cycle a couple of times doesn't remove much water.
    I replaced the motor coupler, but seeing as how the old one looked fine when I took it out (no wear or rubber shavings in the unit), I didn't expect that to fix it...and it didn't!
    What else could be causing the problem?
    I am good at following directions and diagrams, but have mostly worked on belt driven washers. However, I think I could fix it, if I knew what to fix...(Isn't that usually the problem!)
    Feb 2006
    Eagle, ID
    Smile Missed prefix...Model 110.20936990...Sorry!
    Possibly a bad drive hub, basket drive. Something stuck in between the 2 tubs.
    These links should help more:
    ApplianceAid
    RepairGuru
  1. maytag performa - washer spins, but clothes still too wet
    By lifetooshort in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 20th, 2007, 12:13 AM
  2. Kenmore Series 80 Washer slow spin
    By jjenkins in forum Sears Kenmore
    Last Post: December 15th, 2006, 10:21 PM
  3. Whirlpool Washer - Slow Spin Wet Clothes
    By soggypants in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 15th, 2006, 12:50 PM
  4. Kenmore 80 Series washer fading clothes
    By kimberell in forum Sears Kenmore
    Last Post: August 11th, 2005, 09:10 PM
  5. Kenmore Model 70 washer fills slow
    By tomservo in forum Sears Kenmore
    Last Post: March 12th, 2005, 10:40 AM
