April 28th, 2012, 08:49 AM
Kenmore Elite HE4 dryer stopping with clothes still wet
Our dryer shuts off in the middle of the Manual cycle with the clothes still wet. Once the dryer cools down it will start up again. If we run on Med temp it seems to run okay for now. We have blown out the lint on both the Dryer and house so we know its not blocked.
It seems to be the high temp. Its like it is overheating and shutting down.
Should we replace the heating elment? or the thermosat.. and can you provide the part number and where it is at.
Thank you so much
Reason: Added model
April 28th, 2012, 09:32 AM
HE4 is not a model#.
LINK> Where is my model#, I need a part, where should I look for my model number
The motor shuts off in the middle of the cycle?...and won't restart unitl it has sat a while cooling?...if yes, it sounds more like a motor going sour and hsutting on on it's built in safety/thermal switch.
April 28th, 2012, 10:32 AM
model # is 110.85866400
Originally Posted by
kimhen
Thank you so much
April 28th, 2012, 10:41 AM
What happens is it seems to get hot and will stop then once it cools down it starts back up. If you see it and push the start button it will beep 3 times and nothing will happen. It will only restart once it has cooled down.
But If you select the Med temp level it runs the entire cycle fine with no issues.
So if your thinking it the motor I guess I'll need the part number for the motor.
Thank you for all your help.
April 28th, 2012, 07:44 PM
3 beeps is sometimes the temp thermistor...check it first...
Dryer thermistor assembly Manufacturer Number 8577274
Failing that...
Motor, dryer drum drive Manufacturer Number 279787
By maxdreamer in forum Sears Kenmore
Last Post: August 8th, 2010, 11:15 AM
By ominosity in forum Sears Kenmore
Last Post: March 17th, 2007, 12:51 PM
By mvlighthouse in forum Sears Kenmore
Last Post: February 28th, 2007, 01:33 PM
By beijin1 in forum Sears Kenmore
Last Post: December 30th, 2005, 09:01 PM
By shirleypelicanfun in forum Sears Kenmore
Last Post: September 15th, 2005, 11:58 PM
