Results 1 to 4 of 4
Thread: They shoot dishwashers, don't they?
    Springerrr's Avatar
    Springerrr is offline Premium Member
    May 2009
    St. Louis
    Default They shoot dishwashers, don't they?
    Model Number: 665.16969990
    Age: More than 10 years
    OK, I know it is old, but everything seems to be working properly. I jimmied the door so I could watch it spray and drain. I took apart and cleaned everything* as best I could right down to the chopper and drain. Cleaned all the tubes and arms. And still things on the upper rack do not get very clean and all the glasses have a white fog on them.
    Is there just a point when God just wants to bring a dishwasher home?
    Thank you all!!
    *The filter assembly is disgusting inside, but I assume there is no way to open and clean it?
    Yes, the average life of dishwashers now is only 8-12 years.
    Sounds like the wash impeller may be cracked and causing this.
    Here's the impeller kit for your model, the black one is the wash impeller:
    Manufacturer part number 675806 is RepairClinic item number 679717
    675806
    Here's the help video to access/change it:
    The hardest part is getting the impeller screw out.
    Jeff explains here how to do it, if it doesn't want to come out:
    Motor and pump assebly repair and disassemly help
    I had a couple that I tried everything to remove the screw and nothing worked, so the only other option was to just replace the complete motor/pump assembly, its more expensive, but thats basically the only solution.
    Here's the motor/pump assembly for your model:
    Pump and Motor Assembly W10428168 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Correct, you can't open the filter assembly to clean it, you'd need to order a new one:
    Pump Filter 8519553 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Springerrr's Avatar
    May 2009
    St. Louis
    Thank you so much for your reply! I just had the wash impeller out and saw no apparent cracks?
    Ok, then new motor/pump time or new dishwasher time.
    If you can wait till Memorial Day Weekend most appliance stores have Memorial Day Weekends sales, save lots of $$$ on a new dishwasher.
  1. Replies: 3
    Last Post: April 14th, 2011, 05:16 AM
  2. iceing above ice shoot
    By abch&c in forum GE/Hotpoint
    Last Post: July 12th, 2010, 04:35 PM
  3. Bosch dishwashers
    By jeff1 in forum Bosch
    Last Post: November 1st, 2007, 03:55 AM
  4. Jenn Air dishwasher won't drain and I'm going to shoot it...
    By jlanhlan in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 19th, 2005, 06:31 PM
  5. Dishwashers
    By Alan in forum Sears Kenmore
    Last Post: April 14th, 2005, 08:09 PM
