Results 1 to 8 of 8
Thread: Microwave/Range Hood doesn't function
    drooplug is offline Premium Member
    Jul 2010
    Keyport, NJ
    Default Microwave/Range Hood doesn't function
    Model Number: 665.61632100
    Age: More than 10 years
    This is a combination range hood and microwave. When I try to microwave something, the lights comes on in the oven, I hear a clicking sound, but nothing happens. The turntable doesn't turn and the magnetron doesn't operate. The timer does count down. Any ideas?
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Start by checking the door interlock switches for continuity. You'll need a VOM that can read volts and ohms. You might have a bad control panel in which case you might have to start pricing new microwaves. Many parts for this model, including the control board, have been permanently discontinued by the manufacturer.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2010
    Keyport, NJ
    Do those switches check to make sure the door is closed? If so, I don't think they are the problem. The microwave does attempt to cook. I enter a time and hit start and the timer does count down.
    Jul 2006
    Not really. There are two or three interlock switches. They're designed as built in safety devices and not just to make sure the door is closed.
    Jul 2010
    Keyport, NJ
    Ok. You don't happen to have an exploded diagram so I can see where these switches are, do you? So I am just checking for continuity on these, correct?
    Jul 2006
    There are three interlock microswitches. Each switch terminal is marked: COM=Common NO=Normally Open NC=Normally Closed. Unplug the microwave and remove the wires from the switch before testing. Test the switch by opening and closing the door. To access the interlock switches you'll need to remove the grill. Remove the screw on the top of the control panel and it should come off. The switch assembly is accessible on the left where the door closes. If you have any problems or questions just ask.
    Microwave/Range Hood doesn't function-interlock-switches.jpg
    Jul 2010
    Keyport, NJ
    FIXED!
    I opened everything up to give those switches a test. I found that one of the connections to one switch was broken. There were two wires connected to the spade and they burned themselves off. I'm not sure why this happen, but I suspect poor workmanship in the connection. I was able to reconnect the wires and the microwave i snow functioning.
    Jul 2006
    Cool! Easy fix!
  1. Kenmore Microwave/Range Hood won't heat
    By jwes in forum Sears Kenmore
    Last Post: May 1st, 2012, 05:18 AM
  2. Maytag Over the Hood Microwave
    By Bill Ward in forum Microwaves
    Last Post: April 20th, 2012, 08:52 AM
  3. Replies: 10
    Last Post: February 18th, 2012, 10:55 AM
  4. panel doesn't function
    By ebailey in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 21st, 2011, 12:09 PM
  5. Replaced Bulb Under Microwave now no High function
    By Rodehog in forum GE/Hotpoint
    Last Post: February 24th, 2009, 05:10 PM
