June 19th, 2012, 08:41 PM
Warm Surface Light Stays On (Right Front Burner)
Hi All,
Glad to have found you!
I have a 2009 Sears Canada Range: C970-604122.
Even when cool, the Warm Surface Light (one for each burner) associated with the right-front burner remains 'on'. As far as I can tell, the element still performs normally (though it heats a bit slower than it's left counterpart, perhaps due to heavier use). How can I test the burner & controller to determine what is in need of replacing?
I believe they are discussing this problem here:
Flat top hot surface light stays on?
Thanks in advance!
Gorf
June 20th, 2012, 06:21 AM
Canadian model#'s are for the most part not online.
Safety switch on the element is reponsable for turning the light on and off, it is likely stuck on and needs replacing.....most only come with the element now = new element time.
June 22nd, 2012, 10:53 AM
Thanks Jeff for the reply. I've found a part diagram for the model here:
ftp://ftp.electrolux-na.com/ProdInfo...5995476883.pdf
I haven't figured out where to buy parts from, but it's a start. We'll see how she goes.
June 22nd, 2012, 06:34 PM
By David633 in forum Sears Kenmore
Last Post: July 16th, 2012, 04:53 AM
By Complies in forum Sears Kenmore
Last Post: November 26th, 2010, 10:14 AM
By redline808 in forum Sears Kenmore
Last Post: October 16th, 2010, 11:10 AM
By weathp in forum Sears Kenmore
Last Post: November 18th, 2007, 09:57 AM
By BD618 in forum Whirlpool/Roper
Last Post: September 11th, 2007, 10:40 AM
