July 4th, 2012, 11:00 AM
Kenmore washer Drive Block Question
I had a loud squeal during the spin cycle. I removed the inner basket and removed the drive block. the tube was loaded with nasty smelling stuff.
The inside tube of the spin basket seems pretty clean.
I put the washer into the spin cycle without the basket on and it does not squeal anymore.
Could the drive block have cause the squealing noise? I don't want to replace the drive block if that will not correct the problem.
July 4th, 2012, 11:43 AM
Here's the tub drive block for your model:
Manufacturer part number 389140 is RepairClinic item number 2858
389140
This video shows how to check and replace the drive block:
July 4th, 2012, 01:04 PM
It has the cut outs. Like I mentioned, it does spin, it was just squealing very loud at the begingingof the spin cycle. Now with the tub out, there is no squeal.
Here are two pictures that might help show the condition.
July 4th, 2012, 02:12 PM
I need to see a picture of the top of it.
It looks pretty worn out anyways, I'd change it if I was you.
The squealing can also come from the clutch with a load on it.
Description of the symptoms I would check:
Clutch (try to spin the clutch band inside the clutch drum . It should be very hard to spin by hand)
Clutch Assembly (part #2670) from RepairClinic.com
drive block (make sure the 2 slots that engage the "EARS" in the basket drive are not worn out
Drive Block (part #2858) from RepairClinic.com
Basket drive (check to make sure the 2 "EARS" at the top that engage the drive block are intact
Basket Drive (part #1254) from RepairClinic.com
July 4th, 2012, 02:53 PM
Thanks for the advise. One question, how do i check the clutch? Do i have to pull the transmission?
July 4th, 2012, 03:51 PM
Click this link: Clutch Assembly (part #2670) from RepairClinic.com
There is a video in that link to show you.
July 5th, 2012, 11:56 AM
Thanks for the great info! When I took the clutch out, the retainer spring that holds the brake cam driver actually fell off and was wedged under one of the shoes on the clutch!
I put everything together, but I have a bigger problem. The shaft where the spring clip attaches to is worn down somehow to where there is basically no groove left to put the spring on to hold the plastic cam driver.
Am I going to have to replace the drive tube now?
Jim
July 5th, 2012, 12:43 PM
Yes Jim, no other choice but to replace it.
July 5th, 2012, 12:59 PM
ugh,,,,I don't know,,,$125 on a 15 year old machine,,,i put it back together and I think the early squeal is that plastic cam driver dropping down on the clutch.
It is spinning great now, but just has that squeal in the beginning of the spin cycle.
Thanks for your help.
July 5th, 2012, 03:53 PM
i put it back together temporarily leaving that clip off since it was off all ready. it still makes the same squeal when it spins, but now it howles during the rinse cycle. did i maybe put something back together wrong?
By Ipswich in forum GE/Hotpoint
Last Post: November 2nd, 2011, 02:09 PM
By james330i in forum Sears Kenmore
Last Post: March 31st, 2010, 11:35 PM
By BillS in forum Sears Kenmore
Last Post: July 12th, 2007, 11:02 AM
By tsswetsit in forum Sears Kenmore
Last Post: October 25th, 2005, 12:20 AM
By Pahls in forum Sears Kenmore
Last Post: January 22nd, 2005, 10:53 PM
