Old March 3rd, 2006, 12:03 PM
nasus is on a distinguished road
Question kenmore 80 - draining while agitating
After surviving a night of below freezing temperatures, my Kenmore belt drive washer now starts draining as soon as it clicks in to the agitation part of the cycle. It does not drain while filling, and it stops draining if you pull out the timer knob. All other parts of the cycle function properly(except for constant draining). When it is supposed to be draining, it drains a little faster.
The drain hose is where it always functioned properly.
Not sure what part to replace or what to check?
Its a Kenmore 80 Heavy Duty+ #82380710, thawed out with a space heater
Old March 4th, 2006, 08:57 AM
Sounds like either the wigwag/transmission is bad , or your water pump is bad.
Unfortunately they don't make the transmissions for these anymore.
This link will help you find which one it is:
http://www.applianceaid.com/beltwasher.html
Kenmore Elite Washer not draining kogawa Sears Kenmore 5 October 8th, 2007 11:04 PM
Kenmore washer leaking water and not agitating or draining - help! Christina Sears Kenmore 13 August 7th, 2006 09:31 AM
Kenmore not draining...worth repair? $$$$ Joules Sears Kenmore 13 July 8th, 2006 01:35 AM
Kenmore Heavy Duty 80 not draining esura Sears Kenmore 3 April 6th, 2006 10:37 PM
Kenmore 70 series (washer) draining problems kennyw Sears Kenmore 7 January 19th, 2006 10:32 AM
