Results 1 to 10 of 12
Like Tree1Likes
Thread: No cooling at all from fridge
    bobl is offline Premium Member
    Jan 2008
    Austin, TX
    Default No cooling at all from fridge
    Model Number: 106.61252101
    Fridge stopped cooling - there is a low regular humming sound for long period of time with fan running, possibly an occasional slight click every 5 - 10 minutes, eventually the fan and humming stop, then after some time they cycle back on.
    Failure is coincident with period of regular thunderstorms, so I'm wondering if we had a voltage spike that knocked it out.
    I'm completely ignorant about refrigerator operation/troubleshooting, but the unit is 9 years old and I'm wondering if it's worth repairing. I'm leaning towards a new one.
    Any thoughts?
    Hi bobl,
    Its either your compressor start device relay/overload or compressor itself thats bad.
    Follow the guide here:
    [FIXED] How to replace a (Whirlpool/Kenmore Model 106) Refrigerator Start Relay
    To check the compressor start device relay/overload:
    What I do is unplug the refrigerator, then remove the wiring(mark down where the wires go) then remove the relay and overload(the white piece behind the relay) then I shake the relay to hear it rattles, if it rattles, then its broken inside and thats the part you would need to replace.
    Your model may have the relay/overload combined into a single white or black piece, just remove that and shake it.
    I use an ohm meter as well to check for continuity on both the relay and overload if the relay doesn't rattle.
    Here's the compressor start relay for your model you can order here if needed:
    Manufacturer's Number: 2212964
    2212964
    Jan 2008
    Austin, TX
    Hi Jake -
    Thanks for fast reply.
    Relay is solid, no noise when shaking, no visible scorch marks, wiring looks good. Is it easy to check compressor windings and relay contacts? I'm not sure which terminals on relay are supposed to be N/O and N/C. Should I hook it back up and plug it in to listen for a particular noise from compressor to help troubleshoot?
    -Bob
    Jan 2008
    Austin, TX
    BTW - local sears has this one on sale today... I'd be interested if you've had any luck with these units.
    22.7 cu. ft. Bottom Freezer Refrigerator- Kenmore-Appliances-Refrigerators-French Door Refrigerators
    Just put your meter in the 2 holes on the relay and see if your meter moves to 0-1 ohm with the refrigerator unplugged.
    That refrigerator you posted looks like a Kenmore made by LG, I very little knowledge of LG products.
    But it looks like a good price, so if you buy it just get the extended warranty for at least 5 yrs on it.
    Jan 2008
    Austin, TX
    Just to be clear, the compressor facing side has the 3 slots for run/start/com , the other side has 2 slots for a big cap and two slots for the input wires.
    The two holes on the relay to be tested are where the input wires go as opposed to anything on the compressor side... correct?
    Jan 2008
    Austin, TX
    Ah - I get it, I need to check the side that energizes the relay through the relay coil. If that's "open" or super high resistance, then relay is bad.
    Jan 2008
    Austin, TX
    Looks like relay is shot. No continuity (infinite resistance) across the energizing coil.
    The compressor measured
    run to com ~ 5 ohms
    start to com ~ 7 ohms
    run to start ~ 11.3 ohms
    using very cheap multimeter which probably explains why I didn't get 12 ohms.
    -BOb
    Jan 2008
    Austin, TX
    Jake -
    Thanks for your help on this. I went ahead and ordered the part you showed me above.
    -Bob
    Yes Bob, on the relay itself where it plugs into the compressor, the two holes that are in parallel to each other.
  1. Fridge Not Cooling, Freezer Is But Iced Up In Back, Water Leaking Into Fridge
    By mpkeith in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 25th, 2011, 12:51 AM
  2. Maytag fridge click/hum cycling off on every few seconds cooling/not cooling
    By Mippete in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 8th, 2011, 10:19 PM
  3. Replies: 15
    Last Post: February 26th, 2011, 11:53 AM
  4. Kitchenaid Fridge not cooling properly on fridge side
    By mgreenb561 in forum KitchenAid
    Last Post: February 2nd, 2011, 09:51 PM
  5. please help with servis fridge freezer,fridge not cooling
    By azza in forum Refrigerators & Freezers
    Last Post: July 26th, 2007, 04:22 PM
