Results 1 to 8 of 8
Thread: Oven won't heat
    Cakie is offline Member
    Aug 2012
    Colorado
    Unhappy Oven won't heat
    Model Number: 911.47089100
    Neither the bake nor the broil element will heat. The clock and controls light up. We replaced the controller board but this did not solve the problem. What else can we try?
    Is this the part you replaced:
    Oven Control Board WB27T10305 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Does the touchpad buttons still work and let you set the temperature on the oven? But no heat at all?
    Turn the breaker off to your oven and open the control panel and ohm test your thermal fuses(take the wires off them first) #158 and #159 here:
    http://c.searspartsdirect.com/lis_pn...0106-00001.png
    And see if they both have continuity.
    Here's the thermal fuse #158:
    Thermal Fuse WB24T10060 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Here's the thermal fuse #159:
    Thermal Fuse WB24T10059 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video:
    Aug 2012
    Colorado
    Thanks so much for your reply. Yes that is the board we ordered and replaced. The touchpad buttons work and even make clicking noises like they are telling the oven to heat up, but no heat in the elements. I will try testing the thermal fuses when I get home tonight.
    Cakie
    Ok, keep us posted.
    Aug 2012
    Colorado
    Jake, we tested and #159 did not show continuity. We have ordered the part. Will let you know if it works next week when we get it. Thanks a million.
    Cakie
    Ok, keep us posted.
    Ok Cakie, thats the issue then, yes keep us posted.
    Aug 2012
    Colorado
    Default Fuse did not work either
    Hi Jake,we finally got switch #159 and replaced it, but it did not fix the problem. The oven still will not heat. Any other ideas?
    thanks,
    Cakie
    Thats odd, that should of fixed it. Then I'm stumped as well to what it could be.
    You'll likely need to have Sears come out and see whats causing this.
  1. How to fix oven that won't heat up
    By Kpan in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 13th, 2012, 06:09 PM
  2. Replies: 9
    Last Post: February 13th, 2012, 12:47 PM
  3. Replies: 3
    Last Post: February 19th, 2011, 10:09 AM
  4. Oven Will Not Heat Kenmore Oven/Micro Combo
    By millermanmm in forum Sears Kenmore
    Last Post: December 10th, 2010, 10:49 PM
  5. Replies: 1
    Last Post: September 29th, 2006, 10:41 AM
