August 9th, 2012, 04:48 PM
Wash machine making noise during spinning
Hello,
My washer makes a tremendous noise during spinning cycle. I looked at the drum (front loader washer) and noticed that it is not turning concentrically.
The tube must be rubbing, I can see marks from the plastic (on the outside of the tube) eroded from some friction with the tube most likely.
Thanks for suggestion on how to tackle this new project!
August 9th, 2012, 07:43 PM
BIG $ repair or new washer time....esp since it sounds like the inner wash basket support is broken and the tub is rubbing/scraping the outer shell.
Rear outer tub with bearing and shaft seal Manufacturer Number 285984
Complete inner tub Manufacturer Number W10250573
Outer tub, front Manufacturer Number 285982
August 10th, 2012, 04:14 PM
Thank you Jeff, I am sorry to hear a not so optimistic news from you, my last one was better!
However, before I decide anything, do you have any recommandations on how to take the washer apart so I can see for sure that it is the real problem, then I will decide my next step.
Thanks.
August 10th, 2012, 07:55 PM
Should help....
www.applianceblog.com/manuals/DuetWasher.pdf
....only way to know is to take apart....set aside several hours!
August 11th, 2012, 09:34 AM
Originally Posted by
jeff1
Thanks Jeff,
I have started to take the beast apart, I am at the point that I need to remove the front outer tube (which surounds the stainless inner rotating tube) because I still can't see why the inner tube is turning out of round, while on the back the rotation seems to be ok. Is possibly the axle bent?
Anyway, to remove the front outer shell I suppose that I have to remove all the clamps around it? at least 20 of them.
What do you think?
Thanks in advance!
August 11th, 2012, 11:45 AM
Jeff,
I finally took the front shell apart, the inner tube is turning round on the back but out od round on the front. Could it be a fabrication defect and that the tube was warped to start with. Could I do something with the place I baught it from, any ideas?
August 11th, 2012, 12:18 PM
Never seen one do that yet.
Never seen one do that yet....would have started from day one as well.
August 11th, 2012, 09:34 PM
jeff1
Thanks for your time to answer to me Jeff.
I have decided that I won't repair the washer, too costly for a 9 years old one, I will go hunt for a ship and efficient enough one, we have tendancy to pay too much considering that we use only few of these features we pay for!
I am considering to sell some of the parts, when I see how much parts go for, of course I will be extremely competitive!
Christian Vaillant.
August 12th, 2012, 05:55 AM
Might as well...
Buy, Sell or Trade
The Chief's Trading Post Forum
August 18th, 2012, 07:12 PM
jeff1
Jeff,
After taking my washer apart, in fact the inside basket wasn't out of round (just appeared that way), but it was the axle which was bent!
How can this be? from day one? or is it due to too fast spinning?
By rmu96 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: April 25th, 2013, 06:50 PM
By Clgrhodes in forum Whirlpool
Last Post: January 22nd, 2012, 07:50 PM
By shagyk in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: June 26th, 2011, 09:49 PM
By seanandrews in forum Whirlpool/Roper
Last Post: March 20th, 2011, 05:11 PM
By ghefire in forum Sears Kenmore
Last Post: June 4th, 2010, 09:06 PM
