Results 1 to 2 of 2
Thread: Dishwashers
    Alan is offline Member
    Apr 2005
    Post Dishwashers
    I have a 1 year old Kenmore 655.15892100 dishwasher that has never cleaned very well. Recently the wash cycle stopped running - it will still fill with water and drain, but the water no longer "sprays". Initially I could hear the motor trying to turn (a slight humming noise) but now I don't hear this. I had a repair man out and he stripped it down to the "chopper". He removed a few small bits but said that the impeller was very stiff. After putting together again the wash cycle worked. However, right after he left - it stopped again!! I took it all to bits myself, also checked the "check valve" that I've seen many posting say can cause some problems - it looked OK.
    I did all this from within the dishwasher, i.e., I didn't pull it out and work from underneath, but I can not figure out how to remove or at least partially dismantle the impeller/pump assembly.
    I've a couple of specific questions, but any help would be welcomed:
    1. Is there a thermal fuse that can be reset for the pump motor (I presume there is a separate drain motor in this model as it drains OK).
    2. I can turn the impeller by hand - just. It is very stiff. Is there any cleaner that I could pour around the sump that might disolve any junk that could be jamming the impeller? Or do I need a new motor?
    Thanks for any help.
    Alan.
    Post imported post
    Hi Alan,
    If that impeller is the least bit stiff, you will need a new motor/sump assembly. I have seen this problem happen on many of these Kenmore dishwashers.
    Check your warranty in your owners guide, you should have a 5 yr. warranty on that motor/sump assembly for the part only after the first year.
    Did you have a Sears tech. come out?
    If so, theyshould not charge you another trip charge if its within90 days of his or her first visit.
  1. Bosch dishwashers
    By jeff1 in forum Bosch
    Last Post: November 1st, 2007, 03:55 AM
  2. Dishwashers with Stainless Tubs.
    By cyt18guy in forum General Appliance Chat
    Last Post: October 4th, 2007, 11:46 AM
  3. kenmore mod 665.17609301 won't dry
    By jetdoctor1 in forum Sears Kenmore
    Last Post: April 21st, 2007, 11:26 AM
