Old March 20th, 2006, 05:05 PM
rkgrp is on a distinguished road
Default Kenmore Cold Freezer - Warm fridge Frost free failure
Kenmore Refrig. Model 106.53259202
Recently we moved this refrig. (approx. quarter mile). When we moved we had to put it on sidewise on a pickup truck as we couldn't lift it.
After we moved (Feb 1st week) we started realizing 50 deg. on Fridge side and a 10 deg freezer. I checked the freezer side everything (Condensor, Evaporator, fan motor and fan) was normal. Even drain pan and drain whole were clear and no dust. Then I checked the Air Diffuser assembly on top left in the fridge side, felt it was the problem as it was closed all the time, preventing the air to flow. so pushed it manually to keep it open with small knife. It gave few clicking sound and it didn't make any clicks after that. Now the air vent is open and is blowing cold air to fridge and it is works good, but now I left with frost free failure. Now freezer is blowing more cold air. I think forced diffuser to open caused this frost failure. Please help me identifying the root cause of this failure to bring the frost free system back to normal.
Can air diffuser fail to signal the frost free system not to work? Please help me with your technical expertise to fix this failure.
Below is the detailed explaination of what I did, could have caused this frost free failure.
Checking on Air Diffuser (damper), it was closed and I thought was frozen shut. I used hairdryer to clear small amount of ice formation. Then I could open it with letter opener knife (like small knife). As soon as I turn the power on, it closed with force. Later I pushed it and left the knife to keep it open. I turned the power on, I heard click sound. And I pulled the damper out of the path of freezer and fridge by pushing the hold clip on right top of freezer side. (There is also a black wire connected to air diffuser assembly. I don't know whether it is for grounding purpose sticked with tape on freezer wall). I did same thing by keeping the diffuser assembly on my hand to see whether it closes again. It did the same, so I inserted the knife and powered on, it clicked once and nothing head after that and I pulled the knife out and powered on, damper didn't close at all, it stayed open. I put the damper back where it was and it was blowing cold air to refrige. side. I felt I broke something by inserting the knife in the damper shut. So damper is not closing anymore. But I didn't realize it will Jeopardize the frost free system.
When I tried to reach back of the freezer I had to unscrew the ice maker assembly and I tried to take the ice maker apart, I pulled the wire joints, I failed as it was hard to take it out by pushing the sides of wire joints. (I am suspecting here also, whether problem of loose connection. But Ice maker works good.).
Please thow some light with youe expertise.
Old March 21st, 2006, 12:59 AM
No the Air Diffuser and the auto-defrost system is seperate, one wouldn't cause the other to fail.
It sounds like your Air Diffuser has gone bad, I have replaced alot of these on this model in the last 5 yrs.
Old March 22nd, 2006, 12:24 AM
Thank you Jake.
Please suggest a place where I can get better priced part (air diffuser).
thanks
Old March 22nd, 2006, 11:37 AM
Here's another appliance parts dealer's price:
P/N: 2216112 DIFFUSER
Old April 4th, 2006, 01:52 PM
dewana421 is on a distinguished road
Default i have the same problem
Hey brother i have the exact problem..and i did exactly what you did and now i have a frost problem...did you get your problem fixed? let me know please..thanks
Kenmore fridge bottom freezing; freezer warm; no water bkmason Sears Kenmore 12 May 28th, 2007 11:00 AM
Kenmore side-by-side...fridge side warm but freezer side fine jpp816 Sears Kenmore 18 May 18th, 2007 11:17 AM
Kenmore Elite BF. Freezer cold, fridge is not. 596.76529500 Dellot Sears Kenmore 1 August 4th, 2006 11:20 AM
Kenmore 253 SxS warm freezer fridge ok Zebra1 Sears Kenmore 3 July 25th, 2006 06:31 PM
Fridge and Freezer cool but not cold - frost only on two coils in freezer. OpenUX Sears Kenmore 7 July 9th, 2006 01:38 AM
