March 25th, 2006, 05:03 AM
High heat setting takes longer than lower settings
My Kenmore gas dryer model 110.74962300 seems to work fine on the Medium-High and lower heat settings, but takes "forever" at the Cotton-High heat setting. Any thoughts would be appreciated.
March 25th, 2006, 12:28 PM
Sounds like a possible exhaust vent restriction, pull your dryer away from the wall and check you venting exhaust hose/pipe for excessive lint or clogs to the outside.
March 25th, 2006, 02:25 PM
OK, thanks. The vent path from dryer to exterior is reasonably clean. I checked that before posting. But, I'll give it a cycle on High with the vent duct removed and see if there's any difference. It is a fairly long duct (9-10'), but it's rigid, so doesn't get too gunked up.
Thanks for taking the time to reply with the suggestion.
March 25th, 2006, 06:55 PM
Ok, sounds good.
March 26th, 2006, 04:55 PM
That was the answer. Worked good as new away from the wall with the vent duct removed. Guess it doesn't take much in the pipe to gunk things up. Are those drill-driven duct cleaning brushes worth the $40 that they seem to cost online?
March 27th, 2006, 12:30 AM
Glad that it was just the lint duct.
Yes, I have never used one myself, but I have heard they work very well.
Here it is online if you or anyone wants to order it:
LintEater Rotary Dryer Vent Cleaning Kit
By KarMarLar in forum Sears Kenmore
Last Post: April 15th, 2007, 03:08 PM
By jml1911a1 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 8th, 2006, 06:06 AM
By K1100LT in forum Sears Kenmore
Last Post: March 11th, 2006, 06:20 AM
By Joanna in forum Frigidaire/Tappan/Electrolux
Last Post: January 21st, 2006, 02:05 AM
By CraigS in forum Sears Kenmore
Last Post: November 12th, 2005, 10:28 PM
