My washer is halting at the rinse cycle and has an error message on the display of "LF" . It is barely trickling any water out. Any ideas ???? It is a model 110.92195110. It fills fine and washes, then drains, then the error code comes on and will not fill back up to rinse.
If your on well water remove cold hose from back of washer and check the screen in the valve.. may be clogged with dirt/grit.....
Yes, as Bam advised, do take off the water fill hoses to your machine and make sure the screens in the water inlet valve are not clogged.
We are not on well water but apparantly somthing is intefering with the water flow. We will check the hoses and filters. Thank You !
Yes, I have seen those inlet water valve screens clog even with city water.
We cleaned the screens and there was some sand in there. I ran one load and it went just fine. When I went to run a second, it did it again. This time I got the message while it was filling to wash. The water was just trickling again. I switched it to warm and it would fill but only with the hot water. Of course I could not rinse because that is cold water only. It is having an issue with cold. Can it be anything else other than clogged screens/hoses. The first load filled fine on cold. I am thinking it may be somthing electrical, not firing, etc. Thanks !
the valve must be hanging up it is either open or closed,.,, replace the inlet valve and you should be ok.. when you remove the fill hoses to change valve run the water into a bucket to flush out the water lines...
We switched the hot and cold valves to see if it was a bad valve. Then I tried to run a load on cold only to see if it was that valve. Still the same problem except I got the error on both wash and rinse. Could it be because we did not flush like you just suggested ?
Its possible...
| Kenmore Washer - no rinse - PLZZ Help! | uzee | Sears Kenmore | 7 | February 15th, 2007 09:50 PM |
| Kenmore Elite Catalyst washer won't drain & spin | Brittgee | Sears Kenmore | 1 | August 24th, 2006 02:04 PM |
| Kenmore washer intermittent burning smell | mvmartin | Sears Kenmore | 1 | February 9th, 2006 11:40 PM |
| Kenmore 80 Series No Cold Water During Rinse Cycle | poweruser | Sears Kenmore | 3 | September 1st, 2005 06:24 PM |
| Kenmore Series 80 Washer does not rinse | ajaykalra | Sears Kenmore | 3 | May 25th, 2005 03:47 AM |
