May 1st, 2011, 09:54 PM
#11
Very Helpful, thanks
Hello, household of 5 and had this same issue. Just fixed with your suggestions. Thank you for posting! Very much appreciated.
May 1st, 2011, 10:30 PM
#12
Good job gin.
August 19th, 2011, 02:45 PM
#13
I am having the same Fdl error...I tried the tightening of door latch and it worked for a while but now the code is back up again....what else should I try...not sure what else to do?
August 19th, 2011, 08:48 PM
#14
Originally Posted by
cbrennan728
Whats the model# of your washer? Click here to locate it.
Read this thread here:
Sears Kenmore HE3T - Door Latch Issue
June 21st, 2012, 12:00 PM
#15
I have the same issue with our washer. The door is closed and I cannot get it open to check the latch and hinges. Any suggestions?
June 21st, 2012, 03:13 PM
#16
June 21st, 2012, 03:27 PM
#17
here to locate it.
Jake mod 11042926202
June 21st, 2012, 03:54 PM
#18
Check your door switch button, its just above the door latch, sometimes that button has broken, or the door has dropped abit, not aligning correctly.
To open the door manually, remove the lower panel (3 Torx screws), reach up and pull the ring on the bottom of the lock.
Here's the door latch switch assembly for your model if you need to order it:
Manufacturer part#8182634 is RepairClinic item#1094190
Lock, door
Here's a photo of the button on one thats broken:
June 21st, 2012, 04:45 PM
#19
The switch looks ok but I am still getting the error code when I close the door
June 21st, 2012, 07:10 PM
#20
Ok, you will need a multimeter to do a ohm test on the door lock switch solenoids at the CCU, the CCU is underneath your top panel on the washer.
By rsestid in forum Sears Kenmore
Last Post: February 11th, 2007, 12:43 PM
By jvanderee in forum Sears Kenmore
Last Post: September 13th, 2006, 12:47 PM
By dansvrcek in forum Sears Kenmore
Last Post: February 11th, 2006, 06:03 PM
By FrustratedDIYS in forum Sears Kenmore
Last Post: December 28th, 2005, 10:48 AM
By edee_em in forum Sears Kenmore
Last Post: September 6th, 2005, 11:49 PM
