June 22nd, 2012, 07:04 AM
#21
How does the top panel come off/
June 22nd, 2012, 10:04 AM
#22
I put the sensor tps in theholes under the numbers but no reading
June 22nd, 2012, 11:20 AM
#23
I assume you got the top off.
Sensor tips?
You need an ohm meter, and the machine has to be unplugged before testing.
June 22nd, 2012, 02:00 PM
#24
I got the top off. I have adigital multimeter with a black probe and a red probe. The unit is seton the 2000 ohm mark
June 22nd, 2012, 02:36 PM
#25
Put it on 200 ohms, not 2000.
June 22nd, 2012, 02:46 PM
#26
If I put it in the holes under the numbers there is no reading.
June 22nd, 2012, 07:48 PM
#27
Ok, now disconnect that same wire connector from the CCU and take the ohm reading from that connector alone.
June 23rd, 2012, 03:42 AM
#28
June 23rd, 2012, 10:37 AM
#29
Then its your door latch switch thats bad, order the new one from the link I posted to it on the previous page of this thread.
June 23rd, 2012, 11:38 AM
#30
Thanks for all the help Jake!
By rsestid in forum Sears Kenmore
Last Post: February 11th, 2007, 12:43 PM
By jvanderee in forum Sears Kenmore
Last Post: September 13th, 2006, 12:47 PM
By dansvrcek in forum Sears Kenmore
Last Post: February 11th, 2006, 06:03 PM
By FrustratedDIYS in forum Sears Kenmore
Last Post: December 28th, 2005, 10:48 AM
By edee_em in forum Sears Kenmore
Last Post: September 6th, 2005, 11:49 PM
