I have a 5-6 year old bottom freezer refrigerator that just decided to stop cooling the frig. The freezer stays nice and cold but there is no air flow in the frig. So far this is what I have read in the manual and checked:
1. Freezer control is on 2. Lights in freezer and frig are working 3. Door seal is good 4. Cleaned condenser coil 5. Checked that damper in upper part of frig is not closed If I place my hand in front of the vent in the freezer air will blow out the vent in the frig. I have removed the cover in the freezer and there is no damper that redirects the air to the frig. This model does have a automatic defrost and I believe I found the timmer in front of the condenser coils. With the compressor running if I turn the dial 90 deg the compressor shuts off and about another 10 deg the compressor starts to run again. I am wondering if I have another fan between the frezzer and the frig vent that has gone bad but there appears to be no way to check the middle of the frig nor does the picture in the manual show an additional fan. I have attached the image. I am not getting air flow from #2 to the top of the frig. Can anyone help with some advice? Thanks in advance. Dirk |
If you can supply us with the complete model# we can show you a parts diagram of the (evaporator)freezer fan assembly. The Air Duct that runs from the freezer up to the refrigerator is located on the far left side of the evaporator behind that freezer panel, its a square duct tunnel, at times I find these clogged with ice/frost and not allowing air up to the Refrigerator. Jake
This was an issue on these a few years back, Amana brought out a replacement air tower. Give us a full model number and we should be able to pull it up.
I wish I had the entire model number. I looked high and low on the outside and inside and found nothing. The only reason I knew the 596 part was that is all that was typed in the manual.
Anyway, I have some good news and hope this may help someone else. After a few hours of sitting back and thinking about how the system works I decided even though this frig has a auto defrost I would remove all the food and unplug for 4-5 hours. After returning to resume the trouble shooting I decided to remove the shelves and look down the air return, the area behind #8 in the picture. I was happy, yes happy, to see a block of ice. So being the adventures type, I decided to remove the cover in the freezer, part in front of #4 in the pic., and found that the ice went from the vent in the frig floor to the bottom of the freezer and under the defrost heater. I used a hair dryer to melt what was left and bingo, good as new. Thank you Jake and Mad Mac for the response I really found some other useful info in this forum. Dirk ![]() |
Sounds good, glad you got it going again Dirk.
I need your help Jake and Mad Mac!
Here I thought I had this taken care of but I have had to defrost it again three days ago and it needs it again today! Wondering if the auto deforst is bad! I am attaching some pictures to help with what I am seeing since I still have no model number. Also, I apologize for all the magnets and stuff on the front. So, here is the front! |
Here is the inside of the freezer before removing the back panel.
Next, here is the inside with the back panel removed.
This is the same area I have had to clean the last two times. The upper area is where the freezer pulls the air from the refrigerator and is getting blocked due to frost.
I think based on the sketch in the manual the box in the lower right corner is the defrost timer. Am I correct? The dial is turning as the frig is running.
| freezer bottom panel | appfrio | Frigidaire/Electrolux | 1 | June 15th, 2007 10:41 AM |
| bottom freezer, locate, replace adaptive defrost board | kro | Sears Kenmore | 12 | December 14th, 2006 02:59 PM |
| Ice under drawer of our Amana bottom freezer model BL20KW | Krinkrose | Amana | 1 | September 20th, 2006 01:53 AM |
| Ice buildup on bottom of freezer | iansmom | Sears Kenmore | 3 | July 6th, 2006 09:35 PM |
| Bottom Freezer (#596) Air Tower Repeatedly Freezing Up | amahler | Sears Kenmore | 17 | June 17th, 2006 07:25 PM |
