Old June 8th, 2006, 06:25 AM
michaelm is on a distinguished road
Default Kenmore Refrigerator Freezer Floor Panrl Removal
I have Kenmore model 106.8770687 that is leaking water into the refrigerator compartment and believe that the drain tube may be clogged. In an effort to get to the drain tube the freezer compartment floor panel has to be removed. In previous posts you mention that to remove the floor panel just remove 2 screws in front and the floor panel just pulls out. The post was for Kenmore model 106. but not specifically for my model. If the removal is the same as my model would you kindly advise the exact location of the two screws (freezer or refrig compartment). If removal is not the same will you be good enough to explain the removal process. I'm OK in removing evaporator cover and ice maker. Once again, thanks.
Old June 8th, 2006, 06:34 AM
This is an older unit - you should be able to access the drain (34) without removing the bottom panel.
Old June 10th, 2006, 05:36 AM
Default Kenmore Refrigerator Freezer floor panel removal
Tank you Mad Mac for the information. michaelm
Kenmore Coldspot Freezer Back-Panel Removal Godot Sears Kenmore 3 February 21st, 2007 09:50 PM
Kenmore Series 90 motor removal petert Sears Kenmore 1 October 11th, 2006 11:10 PM
Kenmore Refrigerator Door Removal michaelm Sears Kenmore 3 June 5th, 2006 10:29 AM
kenmore front loading bearing removal sky_can Sears Kenmore 6 January 3rd, 2006 10:29 AM
Kenmore 80 series timer knob removal Rich46 Sears Kenmore 7 August 15th, 2005 04:53 PM
