Old June 25th, 2006, 01:44 PM
Ted Ted is offline
Ted is on a distinguished road
Default kenmore coldspot s/s ice maker not working
the mod.#is 106.53704201 ,I notice the other day that the ice bin was low and thought we must have been using alot of ice. but then relized that its was just making a few batches a day so i did a search and found this site, did some reading. then pulled the ice maker out to check to see if the the fill tube was frozen it was not. cleaned all the animal fur from underneath "wow" know where i need to vaccum did notice that when i pluged the connector back in on the ice maker and got in back in position it called for water for some reason. Red led on right side blinks twice and stay on solid when it can see the sensor on the other side. checked and cleaned that last night then this morning i walk in to the kitchen to find a large puddle of water in the floor that came from the freezer because i can see ice droplets in the freezer. water been on all day no ice no leak? please help Thanks Ted
Old June 25th, 2006, 07:24 PM
Check the bottom of the freezer floor, does it have an ice build up on it?
When you put your ice maker back in, did the door close tight? If the ice maker is not properly set in its bracket correctly, it can leave the freezer door open just a hair, which would cause condensation to drip on the floor.
Sears Kenmore Ice Maker Overflowing ArtTruex Sears Kenmore 1 June 3rd, 2007 09:16 PM
Ice maker not working soccermom Sears Kenmore 7 April 10th, 2007 08:14 AM
Kenmore Coldspot Ice Maker Stopped Working Izumino Sears Kenmore 5 March 11th, 2007 07:58 AM
kenmore s/s icebergs in ice maker jennie Sears Kenmore 3 September 11th, 2006 07:44 AM
Kenmore side by side ice maker not working Randy Sears Kenmore 4 January 24th, 2006 03:31 PM
