May 29th, 2005, 11:00 AM
imported post
d/w will not drain all the way. Doesn't appear to be a drain hose problem, but I am new to this... It does sound like it is draining and I hear water moving (in the sink drain). After cycle is complete, there is about an inch of water in the bottom. I tried to push cancel/drain and the water in the bottom gets soapy!
Any help will be appreciated...
May 29th, 2005, 07:46 PM
imported post
The drain hose on your model attaches to a 'check valve' (see the link below) which is screwed into the pump housing. That part failing is common for causing incomplete and/or intermittent drains on that design of pump.
LINK > Kenmore 665.15835793 Drain Check Valve
It does sound like it is draining and I hear water moving (in the sink drain). Doesn't appear to be a drain hose problem...
A *partial* restriction in the hose, an air gap on the sink (if used) or the house plumbing connection could also cause some water to remain in the dishwasher. Don't discount anything until it is confirmed. You know the old saying, "When you assume...".
JMO
Dan O.
Appliance411.com
=D~~~~~~
May 30th, 2005, 08:04 AM
imported post
THANKS! I'll give it a try...
May 30th, 2005, 06:21 PM
imported post
davejr wrote:
Let us know how you make out.
Dan O.
Appliance411.com
=D~~~~~~
May 31st, 2005, 05:56 PM
imported post
I've ordered the part (from the link provided) and will let you know after I get it installed. Thanks for your help! Hopefully, I'll be getting back to you soon...
June 4th, 2005, 02:56 PM
imported post
Got the part installed, but the dishwasher still won't drain after a full cycle. The drainhose does not appear to be kinked anywhere (but it is extremely long under the counter). Any ideas?
June 4th, 2005, 06:43 PM
imported post
davejr wrote:
The drain hose does not appear to be kinked anywhere (but it is extremely long under the counter). Any ideas?
Have you tried disconnecting the drain hose from the house plumbing connection and seeing how it drains into a sink or bucket (but at counter/sink level and not just sitting on the floor). That should rule out the house plumbing and maybe the drain hose length as well?
It was working previously *in the exact same installation* without draining problems??
Dan O.
Appliance411.com
=D~~~~~~
June 4th, 2005, 07:16 PM
imported post
I'll try it. Thanks!
Yes. Nothing has been changed (except the new drain check valve). While I had it open, I did clean the lower sprayer and much of the interior surfaces with white vinegar to remove hard water deposits.
More later... Thanks again!
June 8th, 2005, 10:24 AM
imported post
did the vinegar work? I'm having the same problem.
June 8th, 2005, 12:52 PM
imported post
No luck. We had to call for Service. All the guy did was take the sprayers out and clean them. I think he also took out the pump and cleaned the screens. No parts, but it cost $111 for the house call!
By atvdish64 in forum Sears Kenmore
Last Post: April 14th, 2007, 02:56 PM
By Hardly Working in forum Sears Kenmore
Last Post: February 5th, 2007, 11:32 PM
By kitcat in forum Sears Kenmore
Last Post: December 25th, 2005, 08:11 PM
By bradh in forum Sears Kenmore
Last Post: March 16th, 2005, 07:58 AM
By monte1985 in forum Sears Kenmore
Last Post: March 15th, 2005, 02:39 PM
