August 1st, 2006, 01:47 PM
Kenmore 665.16609300 Control Panel Problem
I posted a problem the end of last year with my Control Panel. Back then, one of my LED's was flashing. The suggestion posted was to replace the control panel. I finally did replace the control panel with a new one, and for about 1 week everything worked fine.
Now I have a second problem. I don't have any flashing LED's, but the control panel basically does not work at all. I can only select one or two options, one of which is the normal wash, but the start button does nothing. The only button that consistenly works is the Cancel button.
I have tried resetting every connector including the ribbon cable, but nothing has helped. I even ordered and installed a new electronics circuit, which was worse as I got a flashing LED after installing that. So I put the original electronics back in.
The only other item of interest is that I noticed the dishwasher no longer worked right after we had a bad thunder storm and there was lighting strike close to my house. However, nothing else in the house has shown any problems of electrical damage.
Alan
August 3rd, 2006, 11:25 AM
Unfortunately, this is a very tough one to diagnose, since that thunderstorm and lighting strike was so close to your house.
I would have Sears come out to look at it.
By apd123 in forum Sears Kenmore
Last Post: September 17th, 2007, 08:19 PM
By winston in forum Sears Kenmore
Last Post: February 26th, 2007, 05:30 PM
By e_smith in forum Sears Kenmore
Last Post: November 5th, 2006, 09:48 AM
By arkadeus in forum Sears Kenmore
Last Post: July 7th, 2006, 06:42 AM
By corkyone in forum Sears Kenmore
Last Post: April 29th, 2006, 12:17 AM
