Old August 20th, 2006, 12:25 AM
qweasdzxc63 is on a distinguished road
Default Kenmore Coldspot 106.63182302 Fridge not cool
When I came back after six weeks vacation,the 2003 unit not cool at all. All fans are always running continuously, but the compressor is deadly quiet, not even any clicking sound. I openned the back of the unit and see nothing abnormal. Thanks in advance.
Old August 20th, 2006, 01:18 PM
Even though you don't hear any clicking you will need to check voltage and continuity at the compressor, compressor relay/overload with a volt/ohm meter as described here:
http://www.applianceaid.com/refrigerator.html#clicking
Old August 24th, 2006, 08:05 AM
Thanks Jake.
I mesured voltage btw c and m is 110 and c and s is 110v as well. PLease advice.
Old August 24th, 2006, 08:35 AM
Also, after I unplug the relay ,overload protector and power, I found s and m terminals of compressor are shorted together. 0 ohm.
Old August 26th, 2006, 11:32 AM
You should have continuity between all the 3 terminals on the compressor itself, but if you have continuity on anyone of the 3 terminals on the compressor and to ground, then you have a grounded compressor.
Check the continuity, with the refrigerator unplugged, across the relay terminals, and the overload terminals, if they both have continuity, then you have a locked-up compressor.
Old August 26th, 2006, 01:53 PM
Servicesman came in and found the compressor winding is open btw c and s, c and m. Return it to depot.
Old August 27th, 2006, 09:48 AM
Ok, thanks for the update.
Kenmore Coldspot #106.71209100 - Water leaking into fridge reeboblue Sears Kenmore 2 September 12th, 2009 05:45 PM
Kenmore Coldspot fridge not cooling Christina N Sears Kenmore 1 April 5th, 2007 12:07 PM
Help - Difficulty cleaning coils on Sears Kenmore Coldspot Fridge elbee Sears Kenmore 6 September 8th, 2006 11:44 AM
Kenmore Coldspot frrezer works not fridge Warriorant Sears Kenmore 8 August 5th, 2006 04:42 PM
kenmore coldspot fridge / freezer amco Sears Kenmore 7 August 2nd, 2005 11:32 AM
