June 3rd, 2005, 07:02 PM
Kenmore Elite Model 11060952990 won't heat
I have replaced the Thermal Cut-Off and the Thermostat on this dryer and the heating element came on for about a minute them went off. I stopped the dryer then restarted it and the heating element won't glow. I took the heating element, along with the Thermisitor and Thermal fuse to the appliance store where all three parts checked out ok.
I thought replacing the Thermostat and Thermal cut off would fix it. If I didn't have 240 volts coming into the dryer the heating element would not have glowed that one time?
I would appreciate any suggestions anyone may have on this model.
Thank you.
June 3rd, 2005, 09:26 PM
imported post
**If I didn't have 240 volts coming into the dryer the heating element would not have glowed that one time?**
Unless one of the 240 volt lines was loose somewhere or burnt.
A copy:
Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ... ( your model - even heat board ... relay )
Something here may help.
By danhend in forum Sears Kenmore
Last Post: May 4th, 2011, 09:43 PM
By wcopithorne in forum Sears Kenmore
Last Post: July 9th, 2007, 12:51 AM
By billjes in forum Sears Kenmore
Last Post: June 26th, 2007, 09:27 AM
By LDJones in forum Sears Kenmore
Last Post: January 24th, 2007, 08:41 AM
By gatorx in forum Sears Kenmore
Last Post: December 3rd, 2005, 02:03 PM
