Old August 31st, 2006, 12:11 PM
telecomwiz1 is on a distinguished road
Default Broken Ice Dispenser (GE)
I have a 9 year old Kenmore Refrigerator (GE), model 363.58095890. The through the door ice dispenser has stopped working. The through the door water dispenser is working fine. I took apart the unit and tested the Motor Crusher Dispenser, part #. WR60X0202 by connecting it to a separate 110 Volt outlet. It works fine. I took my volt meter and discovered that there is not current running through the circuit that the Motor Crusher Dispenser is normally connected to. What seems to happen is that there is a very quick tiny burst of current and then nothing. I tested the circuit that runs the ice crusher / ice dispenser Solenoid and that receives power fine. Also the interior light is working fine. I can't figure out what to do now. It is as if there is a blown fuse related to the Motor Crusher circuit, but I don't see mention of that or anything else that might be replaceable that would regulate the voltage. Does anyone have any ideas of what I should do next?
Old September 1st, 2006, 09:41 AM
Its possible you have a short in your dispenser control board.
Can you move that solenoid piston up and down ok?
Lots of times i see that solenoid in the dispenser housing get rusted and lock-up.
Old September 1st, 2006, 11:11 AM
Thanks for your reply. Your first question was: Its possible you have a short in your dispenser control board? My answer is yes, very possbile since the ice dispenser crusher motor test OK when I removed it from the freezer and tested it. Unfortunately, I don't know how tough it is to get to the dispenser control board, but I can look at that this weekend. If I do figure out how to get to it, how do I test it?
Yes, I can move the solenoid piston up and down, that hasn't been the problem at all. The problem is that the ice dispenser crusher motor does move. It appears not to be getting any voltage or current when it is installed in the freezer.
Thanks again!
Peter
Old September 1st, 2006, 11:29 AM
Opphs, I have a typo. I mean to say in the last paragraph that the ice dispenser motor does not move.
Old September 4th, 2006, 07:42 AM
That front little panel should just pop-off to get to it.
As for testing it, I believe you already did as you said in your first post:
Thats a sure sign its bad.
Old September 5th, 2006, 07:53 PM
Thanks for your help! I am ordering the Dispenser Control Board and will let you know if that solves the problem or not.
Peter
Old September 6th, 2006, 01:20 PM
Sounds good Peter.
Old September 11th, 2006, 05:25 PM
Default Success!!!
Way to go Jake. I ordered the part from Repairclinic.com per the link your provided. It arrived today, I installed it, it now works great and even my wife is impressed.
Thanks to you and the folks at Appliance Blog.>>
Sincerely,>>
Peter>>
Old September 11th, 2006, 10:57 PM
Good job fixing it Peter.
GE S/S ice dispenser headache bholdson GE/Hotpoint 4 August 25th, 2007 10:51 AM
ice dispenser flap Paul Giguere GE/Hotpoint 1 October 21st, 2006 11:00 PM
Ice Maker Dispenser Jam - KSRS25FGWH00 Skibumtx KitchenAid 1 October 10th, 2006 02:30 PM
Kenmore Ice Dispenser Flap Door? SpyderMR Sears Kenmore 5 October 10th, 2006 12:15 AM
GE S/S - Occassional Ice from Dispenser mtbahs GE/Hotpoint 3 July 20th, 2005 06:15 AM
