Old September 8th, 2006, 05:43 PM
AmyZhang is on a distinguished road
Default Kenmore Model 596.50692001 condenser fan
Hello there:
I have this 2001 model Kenmore refrigerator recently is acting up. The compressor will work and the right side panel (outside) is getting really hot. I have to "shake" the refrigerator then the condenser fan will kick on. Or, the compressor will continue work until it shuts itself off (self protection?). Can anyone tell me what's wrong here?
Thanks in advance.
Old September 8th, 2006, 08:15 PM
When the condensor fan motor will not run, see if it is getting power or not. A fan motor getting power but not running needs to be changed.
Condenser fan motor
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old September 9th, 2006, 06:17 AM
Default Condenser fan
Thanks for your reply!
I assume that I should measure if there is any voltage on the motor using a voltimeter, right?
Further, I suspect if there is a device that sends signal to the fan has some problem, say a thermal couple somewhere. My theory is that if the thermal couple has defect, then it could not send message and activate the motor.
I will try to see if your suggestion will fix the problem.
Thanks again.
Old September 9th, 2006, 07:49 AM
Correct....check for power there.
Compressor and condensor fan come on and run at the same time...if the compressor is running but the condensor fan motor is not running...the device sending the power there normally -should- be ok.
JRAppliance
Old September 9th, 2006, 01:32 PM
Default Thanks Jeff
Jeff1:
I checked the wiring and you are right! The fan should be on if the compressor is on.
I didn't pull the wire off the connection. If I order the motor and change it myself, I just pull the connectors (to the motor) off or I have to cut them? Is it easy to change?
Best regards,
Old September 9th, 2006, 04:50 PM
Depending on what motor is sent and what motor is in the unit, both may apply...many today have male-female style connectors or wire spade ends that will just pull off. Years ago we always have ot cut the wires and marr connect them back together, very easy and not polarity sensitive.
For the most part, yes.
Tips for this job are here
JRAppliance
Old September 9th, 2006, 06:50 PM
Default Excellent Jeff
I really appreciate your time. I have added those web site to my favorite and I will try later.
Have a good weekend.
Old September 10th, 2006, 05:19 AM
Thankx!
You as well
JRAppliance
Old September 10th, 2006, 05:25 AM
Default Would it damage anything
Jeff:
I am going to order the motor from the website you provided. Is the model showed exactly what I want?
Further, it may take a few days before I could change the motor, the refrigerator is working OK but the left side panel (outside of freezer) could get really HOT. Would this damage the machine? Do I have to cut it off or it's OK to run a few more days like this?
Let me know.
Old September 11th, 2006, 04:10 PM
Yes.
Condenser fan motor
Can damage the compressor.
If you have someplece to put the food, shut it off until the rpeair is done.
JRAppliance
Condenser Fan Direction thornyschizoid Refrigerators & Freezers 1 April 27th, 2008 12:46 PM
Kenmore Coldspot Condenser Fan? Bambachic Sears Kenmore 7 July 17th, 2007 07:57 AM
Kenmore Trio 596.76519500 low evaporator fan cfg Sears Kenmore 3 February 10th, 2007 09:27 AM
GE Profile: Model PDS22MCRBWW - Condenser Fan? jbiv GE/Hotpoint 1 August 6th, 2006 09:31 PM
Old model - having prob finding condenser fan motor farminlund Refrigerators & Freezers 2 July 26th, 2005 10:59 AM
