110-67732794 is the model # - from the aid of this forum, I think it is part # 3392519 that I need to buy. This forum is the best!
It didn't work - I got a new one from Sears & we installed it and still nothing - any suggestions? |
Now you will have to go more in depth with checking everything, you will need a volt/ohm meter and this reading link:
http://www.applianceaid.com/dryers.html Jake
Well, now when my husband did the breaker, it started - sort of the first time it had heat & I thought WOW I am going to get to do laundry - it sort of heats up but not as hot as it should and after it is done, I open the door and it goes dead again. He did the tester at the outlet and got juice to it. Should I start having him test something inside? Can you give me an idea of which one it may likely be?
If your husband turned the breaker off and on and it started to work to some extent, I would look at your home breaker to the dryer being the issue, breakers over time can wear out and start going bad as well.
Read down at the 4th paragraph here at this link: http://www.applianceaid.com/electrical_testing_tips.html Jake
| Sears Kenmore Thermal Fuse Blowing | herrgomes | Sears Kenmore | 5 | February 11th, 2007 11:04 PM |
| Kenmore HD 70 Series, wont agitate - trips fuse box? - but will spin if on drain | otherjohn | Sears Kenmore | 8 | July 11th, 2006 09:22 PM |
| Kenmore 70 Series - Thermal Fuse Keeps Blowing Out | rebepany | Sears Kenmore | 5 | March 16th, 2006 05:56 PM |
| Kenmore keeps blowing thermal fuse. HELP! | tjs | Sears Kenmore | 7 | December 20th, 2005 04:16 AM |
| Kenmore 70 series thermal fuse | kimmyvb10 | Sears Kenmore | 3 | September 15th, 2005 04:09 AM |
