Results 1 to 3 of 3
Thread: Kenmore Microwave Oven Fuse Keeps Blowing
    Belligerent is offline Member
    Jun 2005
    Post imported post
    I have a Kenmore built-in (over-the-stove) microwave oven, Model No. 721.8935090 that is about 14 years old. About a year ago it quit working, and after some investigation, I found the ceramic fuse - after replacing it, all was well for a while.
    Then, a few days ago, the fuse blew again. I replaced it, and got a minute or two into a cooking cycle - I opened the door to check on what I was cooking, shut the door, and the fuse blew again.
    I have always heard that if the same fuse keeps blowing, you have a more serious problem, but I wanted to make sure before I either take the thing somewhere to have it checked further, or trash it and buy a new one.
    I think I read on here somewhere that slamming the door to the oven could make the fuse blow - I didn't slam it THAT hard (the wife and kids do it much harder), but I guess you could consider it slamming.
    Any suggestions on what step(s) to take next?
    Jun 2005
    Post imported post
    Sorry, but should this question be posted elsewhere?
    Yes, i will move it to the Microwave Repair Talk Forum.
    Oct 2004
    Post imported post
    Blowing the internal fuse when open or closing the door is often a sign of a bad/weak/intermittant door switch....sometimes can be the mechanism that pushes/operates the door switches as well.
    2 switches open and one closes when the door is opened, two close and one opens when the door is opened...if one sticks the short switch can/will blow the fuse.
    http://www.applianceaid.com/nuker.html
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
  1. Sears Kenmore Thermal Fuse Blowing
    By herrgomes in forum Sears Kenmore
    Last Post: February 12th, 2007, 12:04 AM
  2. Kenmore 70 Series - Thermal Fuse Keeps Blowing Out
    By rebepany in forum Sears Kenmore
    Last Post: March 16th, 2006, 06:56 PM
  3. Kenmore keeps blowing thermal fuse. HELP!
    By tjs in forum Sears Kenmore
    Last Post: December 20th, 2005, 05:16 AM
  4. Kenmore microwave oven
    By magi in forum Sears Kenmore
    Last Post: September 24th, 2005, 09:31 PM
  5. Kenmore Microwave Oven
    By delastro in forum Sears Kenmore
    Last Post: June 17th, 2005, 03:48 AM
