Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > Sears Kenmore
Old September 17th, 2006, 10:34 AM
Senior Member
badonkadonk is on a distinguished road
Default Model jvm1640bb002
Power went on/off a couple times and the microwave wouldn't work after that. It would come on but would not heat.
I checked the thermostats and one was bad. Part # WB27X1127, I replaced it and plugged the microwave in and the exhaust fan comes an and runs all the time. Unplug the thermostat and the fan goes off.
Any ideas on this one?
Old September 17th, 2006, 11:22 AM
G'day,
The one thermostat on the base area should be open...it closes if the bottom gets too hot from cooking below and turns on the exhaust fan blower.
WB27X1127
Thermal cut-out.
Sounds like the wrong thermostat was installed.
Something that may help...
http://www.applianceaid.com/micro7.html
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old September 17th, 2006, 06:06 PM
Senior Member
Thanks Jeff
I went to the link and followed the directions.
I have one question. When ohming the diode, it ohms in both directions. No infinity either way. Could this be the problem with no heating? The diode is $55, hate to buy it and not need it!!!!
I did notice that the magnetron didn't come on at any time. I ohmed it and it is 0.00. I think that is OK from what I read from another site?
Old September 17th, 2006, 08:02 PM
That can give a problems with cooking yes....most that I see that show continuity in both directions have some kindofa physical trauma ( cracked ) and the unit buzzzzes instead of cooking.
Generally very low, 1-4 ohms....but that doesn't mean it is "ok". Can fail open when power is applied, can act dead.
JRAppliance
Kenmore model 790.9661* oven door problem hammesd Sears Kenmore 13 October 26th, 2008 09:18 AM
Kenmore Model 665-15895792 FLAG Sears Kenmore 3 August 21st, 2006 05:07 PM
Kenmore Model 80 Washer and Dryer - how old? philbee62 Sears Kenmore 5 March 26th, 2006 11:01 PM
Model 110 44832202 emorabito Sears Kenmore 4 September 18th, 2005 11:55 AM
