Old September 25th, 2006, 12:01 PM
shl76 is on a distinguished road
Default Kenmore 15762 Model - Dead! Power outlet is good but no go!
as title says, i have a Kenmore 15762. it was during dry cycle (where the heat comes on) when it went dead. will not come back on, console does not respond no matter which button i press.
power outlet was checked, provides power.
did it blow a fuse?
Thanks in advance to any suggestions/guidance.
Old September 25th, 2006, 12:09 PM
G'day,
Kenmore 15762 Model
Not a model#.
Kenmore model#'s are more like 123.45678910 or 123 45678910
http://www.applianceaid.com/model.html Some model# helps.
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old September 25th, 2006, 12:11 PM
oh, sorry, it's 665.15762.
i forgot to add. when i found the washer dead, there was water remaining in the bottom (failed to drain).
Old September 26th, 2006, 04:02 AM
G'day,
665.15762
I found 665.15762000
Thermal fuse, door switch, main power ( house breaker fuse ), main power wires can make the d/w go totally dead.
Thermal fuse kit with harness
http://www.applianceaid.com/dish.html#dead
http://www.applianceaid.com/kadish2.html
Some helps.
JRAppliance
Old September 26th, 2006, 11:53 AM
thanks Jeff! I'll order the Thermal fuse kit with harness and see what happens.
Old September 26th, 2006, 04:38 PM
If you get a chance, let us know
JRAppliance
Old October 5th, 2006, 06:02 PM
Jeff,
I replaced the thermal fuse but still no go.
i don't think it could be the door switch since it went dead while it was running.
by main power wire, do you mean house fuse? i've tested the outlet and it's good (provide power).
what is the door switch the only thing left on the list?
thanks again,
Sang
Kenmore Model 110.20892.990 good coupler will not spin joker97 Sears Kenmore 14 June 6th, 2007 08:38 AM
Kenmore Washer Model 110 82427800 Is dead brents4 Sears Kenmore 3 March 27th, 2007 08:51 AM
No Power Kenmore model # 70192000 jcioci Sears Kenmore 5 September 20th, 2006 12:27 AM
Kenmore model 665 16914001 no power!!! kgadd Sears Kenmore 3 January 8th, 2006 10:53 PM
Kenmore Elite Model 11062036100 loses power CableGuy Sears Kenmore 4 June 11th, 2005 05:56 PM
