Old October 8th, 2006, 06:47 PM
SpyderMR is on a distinguished road
Default Kenmore Ice Dispenser Flap Door?
Hello,
My Kenmore model # 25359683992 is having a little problem with the ice dispenser. The flap door does not open and prevents the ice from going through. It was working fine and just decided to stop working, granted it is almost 6 years old. Do I just need to replace the solenoid for the flap door? Is it possible that something else is broken? Everything else works, water, crushed ice, cubed ice. Thanks for your help in advance.
Old October 8th, 2006, 11:25 PM
Its likely your heat motor that opens and closes that ice dispenser door has gone bad.
#35 here is your heat motor:
http://www3.sears.com/imaging/ImageP...&titleID=00007
Here is the new one for your model:
Heat Motor
Old October 9th, 2006, 08:43 AM
Thanks for the reply Jake, I will go ahead and order that part. Is this easy to replace or can I do it myself? Thanks again for the help.
Old October 9th, 2006, 11:44 AM
Yes, it fairly easy to replace, just remove #23 & there is a screw under #28 to move then that comes off, then take the 2 screws off from your dispenser, you will see them after you remove #23. Then remove the 4 #26 screws, then get a putty knife and pry out the dispenser housing #4 on both sides, don't worry you won't break it, it has double sided tape on the back of it. Then you will see the heat motor on the right side.
Make sure you unplug your refrigerator before making this repair.
Old October 9th, 2006, 05:33 PM
Thanks a lot for all the help Jake, I will install it once I get the part. Thanks again for the assistance.
Old October 10th, 2006, 02:15 AM
Glad to help Spyder, Let us know how it goes.
Kenmore Elite freezer door left open, ice maker won't dispense tcreasman Sears Kenmore 1 May 6th, 2007 11:21 AM
Kenmore Side by Send ice dispenser not working jacklx1 Sears Kenmore 1 December 27th, 2006 10:44 PM
ice dispenser flap Paul Giguere GE/Hotpoint 1 October 22nd, 2006 01:00 AM
Kenmore front door dispenser water drip bnplu Sears Kenmore 1 October 10th, 2006 05:47 PM
ice maker dispenser door closer pmarcosa Sears Kenmore 1 August 3rd, 2005 10:26 PM
