Old October 9th, 2006, 03:35 PM
sosinc3 is on a distinguished road
Default Dryer Starts, Stops after a few seconds
I have a Kenmore Dryer, model 110.96093800 and today, it started acting up. What is happening is as follows; regardless of the cycle type you select including timed, when you press the start button, it starts and the dryer will even heat up but about 10-30 seconds into the cycle, the dryer starts to slow down, speed up, etc. and then it stops. This whole process takes probably 10-30 seconds. If you then wait, open the dryer door to reset the start switch, wait a few minutes, you can start the dryer up again but the same exact thing happens.fficeffice" />>>
I have made sure there is no lint blockages (took the front, back, hose, etc. off and vacuumed fully).>>
Is there anything else I can check or any ideas what the problem may be?>>
Old October 10th, 2006, 12:22 AM
It sounds like your motor may be starting to go out. Motors are pretty expensive, so if you dryer is over 10 years old, it may be better to invest the repair money into a new dryer.
Here is a good like about troubleshooting your dryer:
http://www.applianceaid.com/whirlpool-dryers.html
Kenmore Series 70 Dryer starts, then stops bmeeks Sears Kenmore 17 June 16th, 2008 03:49 PM
Roper Dryer Starts only runs five seconds stewill Dryers 5 February 16th, 2007 11:15 PM
Dryer starts runs normally then stops cant be started Toadman Sears Kenmore 11 March 30th, 2006 09:15 AM
kenmore 90 series dryer starts and stops kobera Sears Kenmore 3 January 30th, 2006 11:11 PM
Kenmore dryer runs, stops prematurely, and starts again after 30 minutes rest esetlamm Sears Kenmore 3 December 10th, 2005 03:07 PM
