October 16th, 2006, 07:42 PM
665.16682000 goes to drain on start
When start is pressed on this dishwasher it goes to drain with the Cancel led illuminated. and motor will start up and run for about 30 seconds and then shuts down.
This happened once before but was able to clear by removing the control module and draining the capacitors on the the control module.
Appears the control module is latching up, and happens when one of the kids here open the dishwasher before the cycles are completed.
This time unable to clear by draing the capacitors.
Is there some button sequence to reset this unit or my only reset is to replace the control module ?
October 16th, 2006, 11:28 PM
This thread talks alot about this issue:
http://www.applianceblog.com/mainforums/showthread.php?t=1262
Ok, could be a couple of things causing this, first check your lower spray arm for a crack in it, like someone posted in post#14 in that thread. If no crack in that lower spray arm, its possible your pressure switch is bad.
By Hardly Working in forum Sears Kenmore
Last Post: February 5th, 2007, 11:32 PM
By RJGriz in forum Sears Kenmore
Last Post: December 26th, 2006, 11:03 PM
By route62 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 25th, 2006, 12:44 AM
By cefox01 in forum Sears Kenmore
Last Post: April 16th, 2006, 03:53 PM
By jlanhlan in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 19th, 2005, 06:31 PM
