#21
The local Sears store said they would pay for the valve and replacement if I have it done by a 3rd party...The valve is ordered... I hate to drag this fridge back to the store....Works fine except for this.. |
#22
According to Whirlpool who makes the Kenmore refrigerators with a model number begins with 106. The water flow should be about 1ounce per second or 10 ounces in 10 seconds. To check it, put a large glass measuring cup ( about 16 ounces) under the dispenser and start the water flow, when it gets to the two ounce or four ounce mark start couning, one thousand one, one thousand two, one thousand three, and continue until you get to 10 secounds. Pull the cup back to stop the water and see how many ounces there are. Be sure and subtract the ouncees in the cup before you started counting. Do this about three times until you get the hang of it. Then right down the number of ounces you get. Mine is about 7 ounces in 10 seconds. Then if you have a long blue PUR water filter in the bottom front under the freezer door, pull it out and check the water flow again without the filter. It won't leak, they are designed to run without a filter. Mine is about 11 to 12 ounces in 10 seconds. The blue PUR water filter is restricting the flow of water on mine. But that is not my problem, because I didn't select the water filter, Sears did. So your serviceman's comments about the low water flow aren't valid. The reason it can't dispense the amount of water recommended is because of the filter they specified to use.
It is worth replacing the water shut-of valve just in case it has a seal that doesn't fit well. I ended up going to Lowes where they sell those white plastic fences. Got a white rectangle end cap and put it in the tray under the water dispenser. Now when it drips the end cap catches it and being white, the water evaporates and I don't have to clean water stains off of anything. Good luck to you Mike C |
#23
Well, I installed the new valve and bypassed the filter..Seems that has done the trick..It leaks a small bit in the door tray but nothing on the floor,YET!!! My last Sears product for sure........
#24
Sounds like you got it, still holding up this evening as well?
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/6056-kenmore-refrigerator-water-dispenser-drips.html
| Kenmore refrigerator water dispenser drips - Page 3 - ApplianceBlog.com - Appliance Repair Forums | This thread | Refback | September 1st, 2009 09:42 AM | |
| Kenmore SxS 25357682790 Dispenser problem | Gr8tgreg | Sears Kenmore | 2 | April 12th, 2007 10:58 AM |
| Kenmore front door dispenser water drip | bnplu | Sears Kenmore | 1 | October 10th, 2006 03:47 PM |
| Water Dispenser drips about 1 table spoon | jmv | Amana | 3 | September 28th, 2006 02:37 PM |
| Kenmore refrigerator leaking at dispenser | af66 | Sears Kenmore | 3 | July 23rd, 2006 08:33 AM |
| Kenmore Dispenser Solenoid Problem | jeffro | Sears Kenmore | 2 | February 28th, 2006 03:04 PM |
