Old November 14th, 2006, 04:45 PM
weedsnager is on a distinguished road
Default frig has no air flow...freezer works fine
ok here's the problem....frig on top...freezer on the bottom....the frig stopped keeping foods cold...the freezer keeps working...the fan is blowing in the freezer...but no cold air in the frig.....so wee shut everything off and noticed the coils on the rear interior walls were frozen solid with ice........let it thaw out....everything works fine.....a week later...same problem.......we moved into this house a year and a half ago with this frig it worked fine, there was an ice maker in the freezer but it was not hooked up........ so 3 weeks ago...... i ran the water line to the frig and now this is happening......could this be the problem or just a coincidence??? the tube that puts the water in the ice maker looks fine, doesn't look to be cracked or leaking anywhere in the freezer.......the frig is kenmore 165a model#596.72234200, it is less then 5 years old.
Old November 14th, 2006, 08:33 PM
This sounds like you have a auto-defrost part thats bad, either your defrost thermostat, defrost timer, or defrost heater.
You will need to follow the help section here it will tell you how to test these parts:
http://www.applianceaid.com/frig_notcold.html#ff
Old November 15th, 2006, 01:22 PM
ok, i plugged in the frig after it was off for over 30 hours...it ran for a good 4 hours and the coils in the freezer had frost on them...i rotated the small turn thing on the defrost timer and nothing seemed to happen...does that mean either the defrost heater or defrost thermostat are bad?
Old November 15th, 2006, 11:52 PM
Make sure your refrigerator is running before turning the defrost timer, then turn it and when you hear loud click and the refrigerator shuts off, then its in defrost, don't turn your timer anymore, just let it go through the defrost cycle, it should turn itself back on in about 20-40 minutes.
If the defrost timer does all this, then your defrost timer is working, its either your defrost thermostat or heater.
Kenmore Elite: freezer OK, food section too warm, air-damper is open. t2d Sears Kenmore 10 June 23rd, 2007 09:41 AM
Kenmore side-by-side...fridge side warm but freezer side fine jpp816 Sears Kenmore 18 May 18th, 2007 11:17 AM
maytag s/s freezer not working fridge is fine reiavt Maytag/Magic Chef/Admiral/Jenn-Air 1 September 14th, 2006 01:15 AM
Bottom freezer model 596 dms Sears Kenmore 16 June 5th, 2006 12:34 AM
Kenmore top-mount 106.74269400 ice maker works fine, no water from dispenser palibu Sears Kenmore 1 January 29th, 2006 06:27 PM
