Old December 12th, 2006, 10:13 AM
rcforten is on a distinguished road
Default Kenmore 80 Series Gas Dryer Heat Problem
OK, I've searched and done some troubleshooting, but can't figure it all out, so here goes . . .
1. Kenmore Model # 110-72812101 Gas Dryer, approx. 4 years old.
2. Tumbles, blows fine, no heat.
3. Pulled tiny (~1" square) plastic cover out of hole in lower left front panel of dryer - can't seen anything glowing, burning, etc.
4. Removed rear panel to check thermal fuse - 120V on both sides, so I assume it is fine.
5. Opened top panel and removed front panel - can now see everything, but can't start the dryer to observe/"test" since front panel contains the "bearing" for the front of the drum.
6. Checked everything pretty much - 120V pratically everywhere.
7. Disconnected wires to ignitor - shows open circuit with multi-meter (ohms settings).
8. Pulled out ignitor - appears to have burned out (white area with what appears to be a crack - hard to tell).
9. Used one of the long handled lighters to see if it would make the flame sensor "open" (trying to test it - my understanding is if it stuck closed, it could have caused the ignitor to burn out). It never "opened".
So here I am, I know I have a bad ignitor, but trying to figure out if something else caused it to fail so that I can replace that part as well. And not have another burned up ignitor in a couple of weeks!
Any and all help is greatly appreciated!!!
Old December 12th, 2006, 11:28 PM
Your igniter just wore out, nothing made it go out.
When you replace it, it will go many more years.
Here is the one for your model you can order:
icon
icon
Kenmore 80 Series Gas Dryer - No Heat Safekeeper Sears Kenmore 1 May 8th, 2007 09:40 AM
Kenmore 70 series gas Dryer not heating right pflowers Sears Kenmore 1 February 12th, 2007 07:14 PM
series 70 gas dryer heat problem randyskier Sears Kenmore 6 August 29th, 2005 09:16 PM
Kenmore 80 series dryer, gas, no heat heffemontana Sears Kenmore 1 May 1st, 2005 07:16 PM
Kenmore 90 Series Gas Dryer Problem HomeRepairGreenhorn Sears Kenmore 9 March 15th, 2005 01:02 PM
