Results 1 to 5 of 5
Thread: Kenmore gas range "PF" display
    kenandcar is offline Member
    Oct 2006
    chicago
    Default Kenmore gas range "PF" display
    Once again, I'm having trouble with another one of my Kenmore appliances. This time it's my oven. Sometimes, for no reason, whenever the oven is on a higher setting (anything above 400) the oven shuts off and I get the "PF" display. This happens after the oven has been on for a while. Ordinarily, this is supposed to happen if there is a power failure, but there hasn't been one.
    When this oven was new (4 years ago) we had the same problem and Sears came out and fixed it, free of charge. Something about "This problem happens a lot..." and they changed a of sensor or something. Now it's happening again. Any ideas what the problem is, or which sensor may be on the fritz? I've totally HAD it with Kenmore appliances! The model number is 665.72002/72004/72012/72014/...(<----one of those)
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    I believe its a hi-limit thermostat on the back wall,behind the range.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2006
    After reading that, I thought I'd better be more specific. On the back wall of the range up by the top below the console. Sorry about that.
    Is this the one Rick that your referring too?
    icon
    icon
    Jul 2006
    For some reason I'm having a hard time looking up that model. I was thinking it had a 2 wire thermostat much like a dryer t-stat on the back. If not, I think Jake is right it's most likely the sensor.
    Rick
  1. Sears Kenmore Electric Range 790.94854300 F1 Clock Error
    By Lewandowskiifrank in forum Sears Kenmore
    Last Post: December 21st, 2007, 05:00 PM
  2. Kenmore 70 series gas Dryer not heating right
    Last Post: February 12th, 2007, 08:14 PM
  3. Replies: 1
    Last Post: November 11th, 2006, 11:20 PM
  4. Kenmore Elite Gas Range 790.79013102
    By cdeily in forum Sears Kenmore
    Last Post: October 14th, 2006, 10:43 PM
  5. Kenmore 665 range no display, but burners ok
    By frd1963 in forum Sears Kenmore
    Last Post: July 21st, 2006, 12:57 AM
