Results 1 to 6 of 6
Thread: Kenmore front loader 417-29042992
    shoobs is offline Member
    Jan 2007
    nj
    Default Kenmore front loader 417-29042992
    I have had this washer for 7 years, it has had spin cycle issues from the beginning. I had trouble keeping it in balance, it shook the whole house. I solved that problem by building it in to a cabinet. I never had the stinky mold problem, because I do use bleach and hot cycles, and I leave the door open a crack.
    Most recently the cycle dial came off in my hand, the teeth had broken off, $130 later, I am feeling that this is the last thing I would bother to repair. It has only been a month, and now the tub screams and rattles in the spin cyle. It is not off balance. It does finish the cycle, but the clothes have not been getting as dry as they used to, also, I can't stand to listen to the sound. It is REALLY loud. We are a family of 4, and I do 8-12 loads a week. I have read various postings that sound like the same problem, either the struts, $40 repair, or the tub and spider, $220 repair. I had a tiny bit of water leak out the front, but it doesn't seem to be leaking, it is dry inside the cabinet, and under the machine. I checked the door gasket and I don't see any holes. The tub rotates smoothly, but there does seem to be a bit too much front and back play. I opened the front and the back, but everything seems to be in order. The struts (shock absorber like things) seem to be working, but they seem to have small cracks in the white plastic. I'd hate to junk it for a small fix, but I'd hate to throw money into it and have it fail again for something else. Any ideas?
    Jan 2007
    nj
    Default kenmore front loader 417 29042992
    I just noticed in another post that the units made in 1999 were made of leftover parts, this one was made in 10/99.
    With that play in the tub, it sounds like your tub bearing is starting to go out. I would say to save your repair money for a new washer, 8-12 loads a week for 6 years is pretty good for this washer.
    You can get another one of these models for about $600 minus the energy star rebates of about $200.
    Jan 2007
    nj
    That is pretty much what I had decided, but I wanted a 2nd opinion on the diagnosis before I went shopping. Thanks!
    qman is offline Premium Member
    Jan 2007
    CO
    What are the $200 energy star rebates?
    Quote Originally Posted by qman View Post
    One rebate is from your local utility company, and the other rebate is from the state you live in.
    The store where you get your energy star appliance from will give you the 2 rebate forms to send in with a copy of your receipt.
  1. Kenmore 417.42142100 front loader creating holes in clothing
    By citizengeek in forum Sears Kenmore
    Last Post: April 14th, 2008, 12:04 PM
  2. Kenmore 417 ~ Front Loader Washer ~ water problem
    By washertrouble in forum Sears Kenmore
    Last Post: January 3rd, 2007, 09:48 PM
  3. Kenmore front loader won't drain
    By kitcat in forum Sears Kenmore
    Last Post: December 25th, 2005, 08:11 PM
  4. Front loader 417 42052100 partially fills with water
    By mill1012 in forum Sears Kenmore
    Last Post: October 2nd, 2005, 09:17 PM
  5. Kenmore front loader 417.40142000 leaking
    By finney5 in forum Sears Kenmore
    Last Post: August 17th, 2005, 05:55 PM
