Old February 9th, 2007, 08:15 PM
cfg cfg is offline
cfg is on a distinguished road
Default Kenmore Trio 596.76519500 low evaporator fan
I've got a Kenmore Trio 596.76519500 that's about 14 months old (2 months past the 1yr warranty) and today the temp in the fridge suddenly went up to about 60 degrees and hovered there. After reading around this site I vacuumed out the back and cleaned off the condenser coils which while dirty, didn't seem to be affecting much.
The vent in the fridge section (that goes to the freezer) is open.
I took off the back panel in the freezer and there was a light frost over the fins. The evaporator fan was not turning at all, and I flicked it lightly with my finger and it started spinning slowly.
I assume this fan should be spinning much faster since it is what moves cold air up to the fridge? Does it just need to be replaced or am I looking at a more complicated electrical problem that will probably require a tech?
Old February 9th, 2007, 08:33 PM
Yes, your evaporator freezer fan motor will need to be replaced.
Here is the one for your model you can order:
Freezer (evaporator) fan motor
Old February 9th, 2007, 08:42 PM
cfg cfg is offline
Great, thanks for the fast reply Jake! Is there any way to jury rig the fan to keep things cool over the weekend or is it a lost cause?
Old February 10th, 2007, 09:27 AM
I don't know of a way to make it work till you get your new fan motor, I recommend buying about 10-15 lbs. of dry ice, that will make it stay cold for several days.
Kenmore Trio display is all scrambled readsomething Sears Kenmore 3 June 10th, 2007 06:09 PM
Kenmore Trio Not making ice mamafrey Sears Kenmore 3 May 25th, 2007 09:13 PM
Kenmore Trio Noise lfrancis Sears Kenmore 3 July 16th, 2006 11:19 AM
Kenmore Elite Trio 795.75199401 water leaking from door Imsoaks Sears Kenmore 2 June 27th, 2006 03:05 AM
Kenmore TRIO Water dispenser boc120 Sears Kenmore 5 May 9th, 2006 11:06 PM
