February 12th, 2007, 07:42 AM
Kenmore dryer thermistor ?
I have a Kenmore elite dryer model number 11062956100. When the push to start button is pressed it beeps three times and when the button is released the dryer shuts off. From what I read I assume I need to replace the thermistor. However, when I hold the PTS button down and the dryer runs, there is no heat (it vents only cold air). Is this also indicative of a thermistor problem or does this indicate there is something else wrong?
February 12th, 2007, 05:38 PM
This thread will explain everything and how to test the parts pertaining to it:
[FIXED] Another Kenmore Dryer problem
and read posts #262-#264 here:
You can order the thermistor and the motor/heat relay from those posts as well.
Here is a new control board in case you need to order it:
Click photo for pricing/ordering information:
March 10th, 2007, 01:10 PM
I replaced the thermistor and everything worked fine for about 4 weeks. Now the same problem is back. Any ideas?
March 11th, 2007, 10:44 AM
You may need to change that control board now.
By rbusch in forum Sears Kenmore
Last Post: October 22nd, 2007, 12:59 AM
Last Post: February 12th, 2007, 08:14 PM
By esetlamm in forum Sears Kenmore
Last Post: December 10th, 2005, 04:07 PM
By mikefromottawa in forum Sears Kenmore
Last Post: June 14th, 2005, 07:05 AM
