I have a Kenmore 70 series gas dryer and it is getting a little old (about 8 years) when the dryer is started it may or may not begin to heat, so I removed the back panel to check things out..here is what I found
(heats initialy) the dryer starts normaly I can hear a "click" moments after the dryer is turned on, I can see a heating element glow in the heat supply duct and the gas ignites, the burner stays lit for about a minute and then goes out, a few moments later the heating element comes back on but the gas does not ignte and the heating element turns back off. this cycle continues with no heat. (no heat) the dryer is turned on I hear no "click" the heating element does not heat up gas does not ignite and the dryer continues to turn with no heat. (no heat) the dryer is started I hear the "click" and the heating element comes on but the gas does not ignite, heating element goes off and the dryer continues to turn with no heat the above is in about a 5 minute run time each so I can not speak of long term operations (30 min cycle) as far as the gas igniting 10 mins into a cycle, but I do not believe it is.. Any help is appreciated Paul |
You will need new gas coils, You can order them here:
Part#279834 Gas valve solenoid coil kit, 2 and 3 wire, new style ![]() Here is a help link on this too: http://www.applianceaid.com/gas_dryer.html#noheat Jake
| Kenmore 80 Series Gas Dryer - No Heat | Safekeeper | Sears Kenmore | 1 | May 8th, 2007 09:40 AM |
| Kenmore 80 Series Dryer not heating. | JaredYng | Sears Kenmore | 4 | December 31st, 2006 08:28 AM |
| Kenmore 80 Series Gas Dryer Heat Problem | rcforten | Sears Kenmore | 1 | December 12th, 2006 11:28 PM |
| Kenmore 90 Series Gas Dryer Problem | HomeRepairGreenhorn | Sears Kenmore | 9 | March 15th, 2005 01:02 PM |
