July 9th, 2005, 12:40 PM
imported post
I have Kenmore gas dryer 70 series, model 110.97573220. It happened a few days ago. When I unplugged the power and tried to turn the drum by my hand, it makes a similar kind of high pitched noise (like whoooozzzzzcontinuously) but very light. However, this noise got much louder when I turned it on again. Without the noise, the dryer operates as normal, the drum turns and there is heat.
I'm not sure if it is an issue with motor starting to go bad or something stuck inthe fanblower as it seems to be similar problem someone posted before.
http://www.applianceblog.com/forums/...ryer+70+series
I'd like to try to open the fan blower up to see if it could be a similar problem, but I'm not sure how to disconnect the gas pipe from the dryer first. I will appreciate your advices on what to do to fix this buzzing noise and how to disconnect the gas pipe.
Thank you very much
Ted
July 9th, 2005, 06:20 PM
imported post
I checked that link you posted, it does sound like what yours is doing now.
You have the same style with the lint filter on the top, check those links that Jeff posted in that link you posted here.
To disconnect the gas pipe, just turn off the gas supply to the dryer, you should have a shut-off valve near to that gas pipe, then just get a wrench and take off that gas line that connects to the back of your dryer.
If you can't locate the shut-off valve to the dryer, you may have to shut-off the gas supply to your home.
July 10th, 2005, 12:42 AM
imported post
What can I say. You guys are so good. Initially, I didn't quite believe that the fan blower could cause this noise, but I gave it a try by following the instructions. I found debris such as nails, bolts, pens, pencils, coins in the fan blower. I removed them and cleaned the parts. It worked!!! No more buzzing noise. It's even quieter than before it started making the noise. The whole process took less than an hour.
Thanks for your valuable advices. Ireally appreciate.You just save me a few hundred dollars on a new dryer.
July 10th, 2005, 07:02 AM
imported post
Glad you got going!
By rcforten in forum Sears Kenmore
Last Post: May 26th, 2011, 12:11 PM
By balex99 in forum Sears Kenmore
Last Post: March 20th, 2007, 05:18 PM
Last Post: February 12th, 2007, 08:14 PM
By atetra in forum Sears Kenmore
Last Post: January 20th, 2007, 04:26 PM
